If iMX8M with DDR3L design,the platform need to patch bl31.bin?
1,190 次查看
felixhsu
Hi All
The community had release for LPDDR4 bl31.bin patch, if customer use DDR3L design platform, the platform need to patch bl31.bin or not?
https://community.nxp.com/docs/DOC-340179
Thanks.
标签 (2)
766 次查看
Yuri
  Generally the Arm trusted firmware BL31 should not depend on memory type.
The patch is intended for DVFS and will work only with same type memories as our EVK.
Look at the following:
imx8mq GA release: DDR initialization in ATF
Yuri
767 次查看
Yuri
Yuri
