Hi All,
I have issue with display resolution for following Android 11 - CAR (mek_8q_car-userdebug) and CAR2 (mek_8q_car2-userdebug) build.
But, resolutions is proper with General Android 11 (mek_8q-userdebug). So, from this display timing parameters and frequency proper. Because it is proper with general android 11.
What could be the issue with CAR build w.r.t Display resolution ?
Please read the chapter 8.3 in Android Usr's guide about the Display configuration.
Documentation could be downloaded from here:
Thank you @jimmychan for the reply,
I tried following but it is not working,
ro.boot.gui_resolution=720p
ro.boot.displaymode=720p
Exactly, I am getting this display resolution issue under CAR and CAR2 build. Not in General Android build.
Hi @jimmychan
There is no error message. I able to check the current resolution by using wm size command. As per current requirements the size is 1280x720.
But, resolution is not proper
Hi @jimmychan ,
Basically, it is look like Car Launcher overlap issue. Please conform.
Hi @jimmychan ,
PFA,
I attached the boot log.
Currently I am using MIPI Display with 1280x720p with CAR build (Android 11 Automotive)
