Dear All,
Hardware: IMX8QM-MEK
Software: Embedded Linux (L5.10.52) Weston Wayland
I have some questions about the DRM and DISPLAY on IMX8QM-MEK board
1. How many drm is present in IMX8QM-MEK board ?
Only one drm - I am right ?
2. Is one drm able to support more display in independent mode ?
it will not support display independent mode if more than one display present and if one drm - am I right ?
3. Is it possible to run more than one weston client on one drm ?
One weston Client for one drm, not more than weston client for one drm - am I right ?
4. Is it possible to make touch input for each display ?
I connected two display and touch is working but I am not getting touch event for secondary display.
Will you please provide the some details or documentation for IMX8QM-MEK display (MIPI-DSI-HDMI) frame flow for along with those questions answered.
已解决! 转到解答。
Hi Vinothkumar
i.MX DRM drivers folow general Linux DRM framework described in documentation below
https://www.kernel.org/doc/html/latest/gpu/drm-internals.html
so may be suggested to post those questions on kernel mail list:
http://vger.kernel.org/vger-lists.html
In general i.MX8 series support multiple LCDs, one can look for example
Also may be useful
https://lists.freedesktop.org/archives/dri-devel/2015-May/083707.html
Hi Vinothkumar
Also may be useful
