hello all
what would be the best approach to write qt apps for imx8mq ?
i have a plan to use qt5 creator
regards
Nagendra
you can build fsl-image-qt5-validation-imx image for your board, which includes qt5, for more detailed information, pls refer to the i.MX_Yocto_Project_User's_Guide
Hi I totally new to Yocto & Linux environment.
Could you please provide ref document to write qt apps for imx8.
Thank You!
Hello Joan,
thanks for support
yes, i am using qt5-validation-imx image .
my question is , do we have any document or procedure to setup ans use qt-creator IDE (on-windows) to develop apps for imx8mq-evk ?
maybe you can refer to the document as below:
