Our sensor is sending RAW 12 ,but only 10 bits are valid. So
data need to be shift left by 2 bits.
video pipeline is currently setup as, sensor -> csi -> isp.
How and where can I have data shifted left by 2 bits in this video pipeline?
Did you try to declare the video to be Bit in the kernel driver and in the isp-imx wrapper?
I suppose the Bayer pixel will be transmitted as 16bit/pixel anyway and the IP will do the shifting automatically according to the bit depth you have declared in the driver.
malik_cisse,
Thanks for the suggestion.
How do you "declare the video to be Bit in the kernel driver and in the isp-imx wrapper"?
Could you point out the files and format?
