IMX8MM-EVK power supply of ARM cortex M4
671件の閲覧回数
ajita02
Hi all,
I want to know what supply ARM cortex-M4 uses on IMX8MM-EVK. I know that ARM A-53 uses VDD_ARM. Please provide me a lead.
Thanks & Regards,
Ajita
iMX8MMINI #ARM-CM4
5 返答(返信)
638件の閲覧回数
Chavira
Hi @ajita02!
Thank you for contacting NXP Support!
VDD_ARM and VDD_SOC are the core supplies, if you want to use only the M4 core you have to use at least U-boot to load the binary to the M4.
Please check our getting started guide on how to run programs on M4 core on your board
https://www.nxp.com/document/guide/getting-started-with-the-i-mx-8m-mini-evkb:GS-iMX-8M-Mini-EVK?sec...
Best Regards!
Chavira
621件の閲覧回数
ajita02
There are 3 states in PMIC suspend, Idle and run in which VDD_SOC is on. VDD_ARM is On in Idle and run states. I want to know that can we operate M4 in PMIC suspend state? I want to detect USB detection interrupt in PMIC suspend state. I want maximum power saving so A53 can be in off state.
604件の閲覧回数
Chavira
Hi @ajita02!
According to our application notes the A-Core cannot be turned off.
Please check the "AN12410" and the use cases.
https://www.nxp.com/docs/en/application-note/AN12410.pdf
For your purpose I recommend the iMX8ULP, check the "AN13914" and the use cases.
https://www.nxp.com/docs/en/application-note/AN13914.pdf
Best Regards!
Chavira
632件の閲覧回数
ajita02
Can you tell me what supply M4 core uses? does both supplies VDD_SOC and VDD_ARM are needed to operate M4? what are the things depends on VDD_SOC?
654件の閲覧回数
ajita02
Also what are the components uses VDD_SOC power supply?
