IMX8M Plus camera noise reduction
A_Hiroki
Hi Community!
The i.MX8M Plus reference manual states that the camera's ISP has a filter function to reduce noise.
・Denoising pre-filter
・Filter (Noise reduction)
・Enhanced Chroma Noise Reduction (CNR)
I have a few questions.
Which register should I operate to turn on these filters?
What exactly are these filters? Are there any formulas for calculating the filters?
Thank you in advance for your help
Hiroki
khang_letruong
Senior Contributor III
Hi @A_Hiroki,
I am afraid that the algos relevant to the ISP on iMX8MP are not open to public.  You might need to ask the NXP FAE in your region.
Khang
khang_letruong
Hi @A_Hiroki,
You can try the VVEXT tool from the isp-imx framework (found in /opt/imx8-isp/bin/ on a running board) and investigate the source code of relevant elements in the pipelines (sensor, isp, dwe, ...) here : https://github.com/nxp-imx/isp-vvcam
Khang
A_Hiroki
Hi, @khang_letruong
Thanks.
On the other hand, is it possible to know somewhere what the noise reduction algorithm is?
I would like to use it to analyze images.
Hiroki
khang_letruong
Hi @A_Hiroki,
Khang
