Hi All
I am trying to run UART Interrupt or UART polling demo .
1.Downloaded FreeRTOS BSP for IMX6Sx
2. build files using ARM GCC .
Following 3 documents to run demo
1. Getting_Started_with_FreeRTOS_BSP_for_i.MX_6SoloX.pdf to load M4
2. FreeRTOS_BSP_for_i.MX_6SoloX_Demo_User’s_Guide.pdf to See steps
3 .i.MX_Linux_Reference_Manual.pdf for details
已解决! 转到解答。
1. A7 window
2. M4 window
To see the demo next what i have to do .. where i have to type and in which terminal board show the output..?
Can some one help me to do this ?
Thanks in advance
Chandini
Thank you Sun.
Before also it was working but i got confused comparing hello world program..
i changed the program the way what ever you type print same 'a' .. then i come to know its printing in M4 window.
Result.
you will get what ever you type
Ex: if you type 'h' you can see in window 'h'
