IMX6Q NVCC_RGMII pin
669件の閲覧回数
qumai
If I do not use the RGMII interface, I just use RMII interface,the power domain of which is NVCC_ENET,so i want to know that does NVCC_RGMII G18 pin have to be connected to a power source,eg 1.5V or connect NVCC_RGMII to GND.
3 返答(返信)
666件の閲覧回数
igorpadykov
Hi qumai
for pin voltage levels it is necessary to follow sect.4.6.2 General Purpose I/O (GPIO) DC Parameters
i.MX 6Dual/6Quad Applications Processors for Consumer Products - Data Sheet
as "OVDD" use  column "Power Group" Table 96. 21 x 21 mm Functional Contact Assignments
NVCC_RGMII, NVCC_ENET should be always powered even ethernet interface is not used.
659件の閲覧回数
qumai
but we have produce  Thousands of boards  ,but  But no problem was found.So is there an accurate statement that no power supply is okay? Power supply is definitely better, but is it possible to have no power supply?
654件の閲覧回数
igorpadykov
Hi qumai
it is necessary to follow sect.4.2.1 Power-Up Sequence, which implies that all power supplies
should be provided
Some supplies can be turned off (if unused), they are described in sect.2.8 Unused analog interfaces
IMX6DQ6SDLHDG, Hardware Development Guide for i.MX 6Quad, 6Dual, 6DualLite, 6Solo Families of Applic...
