IMX6 Android8 sabresd_6dq_car无法启动
tianlj
MX6 Android8
lunch sabresd_6dq_car
可编译成功,烧入设备后,无法启动,屏幕显示:
Cant load android system. Your data may be corrupt. If you continue to get this message, you may need to perform a factory data reset and erase all user data stored on this device.
joanxie
what board do you use?
tianlj
imx6d, lunch sabresd_6dq 可以正常启动,sabresd_6dq_car 不行
joanxie
though menu list has this option, but refer to the Table 1. Build names of enclosed user guide, it seems current sabresd board didn't support this, at least the development team didn't test this
