Hello everyone,
Greetings of the day..
I m trying to integrate the lcd module "SF-TC240T-8050A-CT(ili9341)" on imx6ul. so got one patch from below link and i ported to the kernel version 4.9.51.
Patch to support MPU 8080 LCD on iMX6UL and iMX7D
below showing the output of my lcd ....
what might be the issue...? Please help to solve this issue..
Thanks...
Hi Ganesh
one can check if lcd timings are correct with oscilloscope using
sect.19.3. AC Characteristics ili9341 datasheet
https://cdn-shop.adafruit.com/datasheets/ILI9341.pdf
May be useful to test it in uboot customizing function do_enable_parallel_lcd()
mx6ul_14x14_evk.c\mx6ul_14x14_evk\freescale\board - uboot-imx - i.MX U-Boot
