I.MX6 using HAB key in kernel
734件の閲覧回数
zc_tee
Hi all,
Is there any example where i can use the private key that was fused inside the i.mx6 chip (for secure boot) to do some authentication of some files during kernel boot up?
I had managed to fused the key into i.mx6 chip, and managed to authenticate u-boot (from boot ROM) and kernel (from u-boot). However, i have no idea how to continue to use the key in kernel to further authenticate some files in filesystem.
Any help is appreciated.
Thank you.
Tee
ラベル(2)
2 返答(返信)
402件の閲覧回数
joanxie
I send the document and application note to you for reference,
if you don't think this is enough,  do you mind creating a ticket, then I sent the mail to you. because this is security part, I'm not sure I can share these information publicly,
<Encrypted U-boot Example >.
<http://cache.nxp.com/files/32bit/doc/app_note/AN4581.pdf?fsrch=1&sr=1&pageNum=1 >.
<How to submit a new question for NXP Support >
402件の閲覧回数
zc_tee
Anybody has answer for this?
Tee
