This is the pic of pinmux.c file of enet_txrx_example of imx rt 1060.
I want to ask how actually the values of pin configueration is decided. like 0xB0A9U
Is there any document which states that for achieving some particular function 0xB0A9U , this pin configuration needs to be set?
Solved! Go to Solution.
Hi @achal ,
It's pad control register, not pad mux register. Those value will be written into pad control register.
Jing
Hi @achal ,
This function write SW_PAD_CTL_PAD_xxxx SW PAD Control Register. You can refer to, for example, page 410 in reference manual.
Jing
Here only reset value is mentioned
Hi @achal ,
Jing
