I am working with the evk-imx8mm card and I am adding the uSD m.2 adapter with the 1MW module, I am using Android 9 Pie, I have been able to successfully add the wifi, however I cannot add the bluetooth.
I have based on the development made for the evk-imx8mm-ddr4 which has the cypress module however I could not use the bluetooth. I think it may be because of the change of the UART port. In evk-imx8mm-ddr4 it is in UART1 (ttymxc0) and in evk-imx8mm I want to use it in UART3 (ttymxc2). I have made changes to DTS and disabled port UART1 and enabled UART3.
Is this issue resolved? I am facing a similar issue in Android-11.0.0-1.0.0.
When turning on Bluetooth it is crashing sometimes. Reference Board is MEK-8QM and i am using Nxp's combo firmware (8987)
I have similar error: E bt_btif_config: Config is missing adapter section
Is there any update?
Thank you in advance.
Rahmanu
this is the log
--------- beginning of main
02-06 00:23:17.699 4720 4740 E bt_hci : command_timed_out
02-06 00:23:17.699 4720 4740 E bt_hci : command_timed_out_log_info: 1 commands pending response
02-06 00:23:17.699 4720 4740 E bt_hci : command_timed_out_log_info: Waited 2000 ms for a response to opcode: 0xc03 *matches timer*
02-06 00:23:17.700 4720 4740 E bt_hci : command_timed_out_log_info: Size 3 Hex 03 0c 00
02-06 00:23:17.700 4720 4740 E bt_hci : command_timed_out: requesting a firmware dump.
02-06 00:23:17.701 4720 4740 E bt_hci : command_timed_out: Setting a timer to restart.
02-06 00:23:17.784 3234 3346 E WifiVendorHal: getWifiLinkLayerStats(l.937) failed {.code = ERROR_NOT_AVAILABLE, .description = }
02-06 00:23:17.874 3404 3404 D StatusBar: disable<e i a s b h r c s > disable2<q i n >
02-06 00:23:18.901 3404 3404 D InputEventConsistencyVerifier: TouchEvent: ACTION_DOWN but pointers are already down. Probably missing ACTION_UP from previous gesture.
02-06 00:23:18.901 3404 3404 D InputEventConsistencyVerifier: in android.view.ScaleGestureDetector@f7ef68c
02-06 00:23:18.901 3404 3404 D InputEventConsistencyVerifier: 0: sent at 6856302451000, MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=156.11194, y[0]=156.91827, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=6856302, downTime=6856302, deviceId=1, source=0x1002 }
02-06 00:23:18.901 3404 3404 D InputEventConsistencyVerifier: -- recent events --
02-06 00:23:18.901 3404 3404 D InputEventConsistencyVerifier: 1: sent at 6856302451000, MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=156.11194, y[0]=156.91827, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=6856302, downTime=6856302, deviceId=1, source=0x1002 }
02-06 00:23:18.959 3075 4286 I audio_hw_primary: start_output_stream_primary... 0xf6546000, device 2, address , mode 0
02-06 00:23:18.959 3075 4286 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 2, earpiece 0,
--------- beginning of system
02-06 00:23:18.960 3234 4667 D BluetoothManagerService: enable(com.android.systemui): mBluetooth =null mBinding = false mState = OFF
02-06 00:23:18.960 3234 3259 D BluetoothManagerService: MESSAGE_ENABLE(0): mBluetooth = null
02-06 00:23:18.963 3234 4667 D BluetoothManagerService: enable returning
02-06 00:23:18.965 3075 4286 W audio_hw_primary: card 0, port 0 device 0x2
02-06 00:23:18.965 3075 4286 W audio_hw_primary: rate 48000, channel 2 period_size 0xc0
02-06 00:23:20.204 3234 4667 D WificondControl: Scan result ready event
02-06 00:23:20.207 3234 3258 I EthernetTracker: interfaceLinkStateChanged, iface: wlan0, up: true
02-06 00:23:20.793 3234 3346 E WifiVendorHal: getWifiLinkLayerStats(l.937) failed {.code = ERROR_NOT_AVAILABLE, .description = }
02-06 00:23:21.962 3234 3259 E BluetoothManagerService: MESSAGE_TIMEOUT_BIND
02-06 00:23:22.098 3075 3183 W audio_hw_primary: do_out_standby... 0xf6546000
02-06 00:23:22.701 4720 4740 E bt_hci : hci_timeout_abort restarting the Bluetooth process.
--------- beginning of crash
02-06 00:23:22.702 4720 4740 F libc : Fatal signal 6 (SIGABRT), code -6 (SI_TKILL) in tid 4740 (alarm_default_c), pid 4720 (droid.bluetooth)
02-06 00:23:22.785 4765 4765 I crash_dump64: obtaining output fd from tombstoned, type: kDebuggerdTombstone
02-06 00:23:22.786 3135 3135 I /system/bin/tombstoned: received crash request for pid 4740
02-06 00:23:22.791 4765 4765 I crash_dump64: performing dump of process 4720 (target tid = 4740)
02-06 00:23:22.808 4765 4765 F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
02-06 00:23:22.809 4765 4765 F DEBUG : Build fingerprint: 'Android/evk_8mm/evk_8mm:9/2.3.0-ga-rc2/cmiguel01161619:eng/dev-keys'
02-06 00:23:22.809 4765 4765 F DEBUG : Revision: '0'
02-06 00:23:22.809 4765 4765 F DEBUG : ABI: 'arm64'
02-06 00:23:22.809 4765 4765 F DEBUG : pid: 4720, tid: 4740, name: alarm_default_c >>> com.android.bluetooth <<<
02-06 00:23:22.809 4765 4765 F DEBUG : signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
02-06 00:23:22.809 4765 4765 F DEBUG : x0 0000000000000000 x1 0000000000001284 x2 0000000000000006 x3 0000000000000008
02-06 00:23:22.809 4765 4765 F DEBUG : x4 a62ee5befeff6862 x5 a62ee5befeff6862 x6 a62ee5befeff6862 x7 ff7fffff7f7f7f7f
02-06 00:23:22.809 4765 4765 F DEBUG : x8 0000000000000083 x9 0000fc83a73369a0 x10 fffffff87ffffbdf x11 0000000000000001
02-06 00:23:22.809 4765 4765 F DEBUG : x12 0000fc838a0bf608 x13 ffffffffffffffff x14 ffffffffff000000 x15 ffffffffffffffff
02-06 00:23:22.809 4765 4765 F DEBUG : x16 0000fc83a736f2c8 x17 0000fc83a72ad2d8 x18 0000fc838a0bedca x19 0000000000001270
02-06 00:23:22.809 4765 4765 F DEBUG : x20 0000000000001284 x21 0000000000000083 x22 0000fc838a0bfa90 x23 0000fc838a66ef40
02-06 00:23:22.809 4765 4765 F DEBUG : x24 000000000068ad4b x25 0000fc838a0c0588 x26 0000fc838a0bfd68 x27 0000000000000001
02-06 00:23:22.809 4765 4765 F DEBUG : x28 0000000000000000 x29 0000fc838a0bfa30
02-06 00:23:22.809 4765 4765 F DEBUG : sp 0000fc838a0bf9f0 lr 0000fc83a72a1a90 pc 0000fc83a72a1abc
02-06 00:23:22.840 4765 4765 F DEBUG :
02-06 00:23:22.840 4765 4765 F DEBUG : backtrace:
02-06 00:23:22.840 4765 4765 F DEBUG : #00 pc 0000000000021abc /system/lib64/libc.so (abort+124)
02-06 00:23:22.840 4765 4765 F DEBUG : #01 pc 000000000015ef74 /system/lib64/libbluetooth.so (hci_timeout_abort(void*)+52)
02-06 00:23:22.840 4765 4765 F DEBUG : #02 pc 00000000002296b8 /system/lib64/libbluetooth.so (alarm_ready_generic(alarm_t*, std::__1::unique_lock<std::__1::mutex>&)+216)
02-06 00:23:22.840 4765 4765 F DEBUG : #03 pc 00000000002295a0 /system/lib64/libbluetooth.so (alarm_queue_ready(fixed_queue_t*, void*)+112)
02-06 00:23:22.840 4765 4765 F DEBUG : #04 pc 000000000022d454 /system/lib64/libbluetooth.so (internal_dequeue_ready(void*)+84)
02-06 00:23:22.840 4765 4765 F DEBUG : #05 pc 0000000000232ee8 /system/lib64/libbluetooth.so (run_reactor(reactor_t*, int)+320)
02-06 00:23:22.840 4765 4765 F DEBUG : #06 pc 0000000000232d7c /system/lib64/libbluetooth.so (reactor_start(reactor_t*)+84)
02-06 00:23:22.840 4765 4765 F DEBUG : #07 pc 0000000000234750 /system/lib64/libbluetooth.so (run_thread(void*)+184)
02-06 00:23:22.840 4765 4765 F DEBUG : #08 pc 0000000000083114 /system/lib64/libc.so (__pthread_start(void*)+36)
02-06 00:23:22.840 4765 4765 F DEBUG : #09 pc 00000000000233bc /system/lib64/libc.so (__start_thread+68)
02-06 00:23:23.367 3135 3135 E /system/bin/tombstoned: Tombstone written to: /data/tombstones/tombstone_48
02-06 00:23:23.378 3234 3257 I BootReceiver: Copying /data/tombstones/tombstone_48 to DropBox (SYSTEM_TOMBSTONE)
02-06 00:23:23.434 3079 4329 E android.hardware.bluetooth@1.0-impl: BluetoothDeathRecipient::serviceDied - Bluetooth service died
02-06 00:23:23.435 3079 4329 I android.hardware.bluetooth@1.0-impl: BluetoothHci::close()
02-06 00:23:23.435 3079 4329 I android.hardware.bluetooth@1.0-impl: Skipping unlink call, service died.
02-06 00:23:23.435 3079 4329 I bt_userial_vendor: device fd = 6 close
02-06 00:23:23.437 3234 4466 I ActivityManager: Process com.android.bluetooth (pid 4720) has died: psvc PER
02-06 00:23:23.437 3234 3253 W libprocessgroup: kill(-4720, 9) failed: No such process
02-06 00:23:23.437 3234 3253 I libprocessgroup: Successfully killed process cgroup uid 1002 pid 4720 in 0ms
02-06 00:23:23.438 3234 4466 W ActivityManager: Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
02-06 00:23:23.438 3065 3065 I Zygote : Process 4720 exited due to signal (6)
02-06 00:23:23.442 3091 3207 E display : threadLoop invalid uevent change@/devices/platform/bt_rfkill/rfkill/rfkill0
02-06 00:23:23.443 3079 4329 I android.hardware.bluetooth@1.0-impl: Firmware configured in 15.217s
02-06 00:23:23.808 3234 3346 E WifiVendorHal: getWifiLinkLayerStats(l.937) failed {.code = ERROR_NOT_AVAILABLE, .description = }
02-06 00:23:24.455 4776 4776 W main : type=1400 audit(0.0:3776): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-06 00:23:24.459 4776 4776 I chatty : uid=0(root) com.android.bluetooth identical 2 lines
02-06 00:23:24.459 4776 4776 W main : type=1400 audit(0.0:3779): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-06 00:23:24.469 3234 3252 I ActivityManager: Start proc 4776:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
02-06 00:23:24.560 4776 4776 D BluetoothOppFileProvider: Initialized
02-06 00:23:24.582 4776 4776 V AdapterServiceConfig: Adding HeadsetService
02-06 00:23:24.583 4776 4776 V AdapterServiceConfig: Adding A2dpService
02-06 00:23:24.583 4776 4776 V AdapterServiceConfig: Adding HidHostService
02-06 00:23:24.583 4776 4776 V AdapterServiceConfig: Adding HealthService
02-06 00:23:24.583 4776 4776 V AdapterServiceConfig: Adding PanService
02-06 00:23:24.584 4776 4776 V AdapterServiceConfig: Adding GattService
02-06 00:23:24.584 4776 4776 V AdapterServiceConfig: Adding BluetoothMapService
02-06 00:23:24.584 4776 4776 V AdapterServiceConfig: Adding AvrcpTargetService
02-06 00:23:24.584 4776 4776 V AdapterServiceConfig: Adding HidDeviceService
02-06 00:23:24.584 4776 4776 V AdapterServiceConfig: Adding BluetoothOppService
02-06 00:23:24.584 4776 4776 V AdapterServiceConfig: Adding BluetoothPbapService
02-06 00:23:24.597 4776 4776 I : [0206/002324.597809:INFO:com_android_bluetooth_btservice_AdapterService.cpp(630)] hal_util_load_bt_library loaded HAL: btinterface=0xfc838a999438, handle=0x44882630bcbd79a3
02-06 00:23:24.599 4776 4776 D BluetoothAdapterService: onCreate()
02-06 00:23:24.603 4776 4776 D AdapterState: make() - Creating AdapterState
02-06 00:23:24.605 4776 4776 I bt_btif : init
02-06 00:23:24.606 4776 4792 I AdapterState: OFF : entered
02-06 00:23:24.606 4776 4776 D bt_osi_allocation_tracker: canary initialized
02-06 00:23:24.606 4776 4792 D AdapterProperties: Setting state to OFF
02-06 00:23:24.607 4776 4793 I bt_osi_thread: run_thread: thread id 4793, thread name stack_manager started
02-06 00:23:24.607 4776 4793 I bt_stack_manager: event_init_stack is initializing the stack
02-06 00:23:24.608 4776 4793 E bt_btif_config: Config is missing adapter section
02-06 00:23:24.608 4776 4793 W bt_btif_config: init unable to load config file: /data/misc/bluedroid/bt_config.conf; using backup.
02-06 00:23:24.608 4776 4793 W bt_btif_config: init unable to load backup; attempting to transcode legacy file.
02-06 00:23:24.609 4776 4793 E bt_btif_config_transcode: btif_config_transcode unable to load XML file '/data/misc/bluedroid/bt_config.xml': 3
02-06 00:23:24.609 4776 4793 E bt_btif_config: init unable to transcode legacy file; creating empty config.
02-06 00:23:24.610 4776 4796 I bt_osi_thread: run_thread: thread id 4796, thread name alarm_default_ca started
02-06 00:23:24.610 4776 4797 I bt_osi_thread: run_thread: thread id 4797, thread name alarm_dispatcher started
02-06 00:23:24.612 4776 4793 I bt_btif_core: btif_init_bluetooth entered
02-06 00:23:24.613 4776 4793 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
02-06 00:23:24.614 4776 4798 I bt_osi_thread: run_thread: thread id 4798, thread name bt_jni_workqueue started
02-06 00:23:24.614 4776 4793 I bt_btif_core: btif_init_bluetooth finished
02-06 00:23:24.614 4776 4793 I bt_stack_manager: event_init_stack finished
02-06 00:23:24.614 4776 4798 I bt_btif_core: run_message_loop entered
02-06 00:23:24.615 4776 4776 I bt_osi_wakelock: wakelock_set_os_callouts set to non-native
02-06 00:23:24.615 4776 4776 I bt_btif : get_profile_interface: id = socket
02-06 00:23:24.615 4776 4776 W bt_btif : do_in_jni_thread: Dropped message, message_loop not initialized yet!
02-06 00:23:24.615 4776 4776 I chatty : uid=1002(bluetooth) com.android.bluetooth identical 1 line
02-06 00:23:24.617 4776 4776 I bt_btif : get_profile_interface: id = sdp
02-06 00:23:24.620 4776 4776 I BluetoothAdapterService: Phone policy enabled
02-06 00:23:24.622 4776 4776 D BluetoothActiveDeviceManager: start()
02-06 00:23:24.630 4776 4799 D BluetoothActiveDeviceManager: onAudioDevicesAdded
02-06 00:23:24.630 4776 4776 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@17368cc
02-06 00:23:24.630 4776 4799 D BluetoothActiveDeviceManager: Audio device added: EVK_8MM type: 2
02-06 00:23:24.630 4776 4799 D BluetoothActiveDeviceManager: Audio device added: EVK_8MM type: 15
02-06 00:23:24.638 4776 4776 D BluetoothAdapterService: onBind()
02-06 00:23:24.639 3234 3234 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
02-06 00:23:24.639 3234 3259 D BluetoothManagerService: MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
02-06 00:23:24.639 3234 3259 D BluetoothManagerService: Broadcasting onBluetoothServiceUp() to 4 receivers.
02-06 00:23:24.640 3234 3259 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@12c4f53
02-06 00:23:24.640 3404 3417 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@57a2d52
02-06 00:23:24.640 3548 3572 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@829baa2
02-06 00:23:24.641 4776 4788 D BluetoothAdapter: onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@c4c11da
02-06 00:23:24.641 4776 4790 D BluetoothAdapterService: enable() - Enable called with quiet mode status = false
02-06 00:23:24.641 3234 3259 D BluetoothManagerService: MESSAGE_GET_NAME_AND_ADDRESS
02-06 00:23:24.642 4776 4792 I AdapterState: BLE_TURNING_ON : entered
02-06 00:23:24.642 4776 4792 D AdapterProperties: Setting state to BLE_TURNING_ON
02-06 00:23:24.642 4776 4792 D BluetoothAdapterService: updateAdapterState() - Broadcasting state BLE_TURNING_ON to 1 receivers.
02-06 00:23:24.642 4776 4792 D BluetoothAdapterService: bleOnProcessStart()
02-06 00:23:24.643 4776 4792 I AdapterProperties: init(), maxConnectedAudioDevices, default=5, propertyOverlayed=5, finalValue=5
02-06 00:23:24.643 3234 3259 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
02-06 00:23:24.643 3234 3259 D BluetoothManagerService: Sending BLE State Change: OFF > BLE_TURNING_ON
02-06 00:23:24.645 4776 4792 D BluetoothAdapterService: bleOnProcessStart() - Make Bond State Machine
02-06 00:23:24.646 4776 4792 D BluetoothBondStateMachine: make
02-06 00:23:24.648 4776 4805 I BluetoothBondStateMachine: StableState(): Entering Off State
02-06 00:23:24.655 4776 4776 I BtGatt.JNI: classInitNative(L875): classInitNative: Success!
02-06 00:23:24.657 4776 4776 D BtGatt.DebugUtils: handleDebugAction() action=null
02-06 00:23:24.658 4776 4776 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@17368cc
02-06 00:23:24.660 4776 4776 I bt_btif : get_profile_interface: id = gatt
02-06 00:23:24.661 4776 4776 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@17368cc
02-06 00:23:24.690 4776 4776 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@17368cc
02-06 00:23:24.692 4776 4776 D BluetoothAdapterService: handleMessage() - Message: 2
02-06 00:23:24.692 4776 4776 D BluetoothAdapterService: handleMessage() - MESSAGE_PROFILE_SERVICE_REGISTERED
02-06 00:23:24.693 4776 4776 D BluetoothAdapterService: handleMessage() - Message: 1
02-06 00:23:24.693 4776 4776 D BluetoothAdapterService: handleMessage() - MESSAGE_PROFILE_SERVICE_STATE_CHANGED
02-06 00:23:24.693 4776 4776 I bt_btif : enable: start restricted = 0
02-06 00:23:24.693 4776 4793 I bt_stack_manager: event_start_up_stack is bringing up the stack
02-06 00:23:24.694 4776 4793 I bt_core_module: module_start_up Starting module "btif_config_module"
02-06 00:23:24.694 4776 4793 I bt_core_module: module_start_up Started module "btif_config_module"
02-06 00:23:24.694 4776 4793 I bt_core_module: module_start_up Starting module "btsnoop_module"
02-06 00:23:24.694 4776 4793 I bt_core_module: module_start_up Started module "btsnoop_module"
02-06 00:23:24.694 4776 4793 I bt_core_module: module_start_up Starting module "hci_module"
02-06 00:23:24.694 4776 4793 I bt_hci : hci_module_start_up
02-06 00:23:24.694 4776 4809 I bt_osi_thread: run_thread: thread id 4809, thread name hci_thread started
02-06 00:23:24.694 4776 4793 D bt_hci : hci_module_start_up starting async portion
02-06 00:23:24.694 4776 4809 I bt_hci : hci_initialize
02-06 00:23:24.696 4776 4809 I bt_hci : hci_initialize: IBluetoothHci::getService() returned 0xfc839ac0e500 (remote)
02-06 00:23:24.697 3079 3079 I android.hardware.bluetooth@1.0-impl: BluetoothHci::initialize()
02-06 00:23:24.698 3079 3079 I bt_vendor: init
02-06 00:23:24.698 3079 3079 I bt_vnd_conf: Attempt to load conf from /vendor/etc/bluetooth/bt_vendor.conf
02-06 00:23:24.698 3079 3079 D android.hardware.bluetooth@1.0-impl: Open vendor library loaded
02-06 00:23:24.698 3079 3079 W bt_vendor: NOTE: BT_VND_PWR_ON now forces power-off first
02-06 00:23:25.214 3079 3079 I bt_userial_vendor: userial vendor open: opening /dev/ttymxc2
02-06 00:23:25.216 3091 3207 E display : threadLoop invalid uevent change@/devices/platform/bt_rfkill/rfkill/rfkill0
02-06 00:23:25.217 3079 3079 I bt_userial_vendor: device fd = 6 open
02-06 00:23:25.218 3079 4812 E android.hardware.bluetooth@1.0-impl: ThreadRoutine unable to set SCHED_FIFO for pid 3079, tid 4812, error Operation not permitted
02-06 00:23:26.819 3234 3346 E WifiVendorHal: getWifiLinkLayerStats(l.937) failed {.code = ERROR_NOT_AVAILABLE, .description = }
02-06 00:23:28.646 4776 4792 E AdapterState: BLE_TURNING_ON : BLE_START_TIMEOUT
02-06 00:23:28.646 4776 4792 I AdapterState: BLE_TURNING_OFF : entered
02-06 00:23:28.646 4776 4792 D AdapterProperties: Setting state to BLE_TURNING_OFF
02-06 00:23:28.647 4776 4792 D BluetoothAdapterService: updateAdapterState() - Broadcasting state BLE_TURNING_OFF to 1 receivers.
02-06 00:23:28.647 3234 3259 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: BLE_TURNING_ON > BLE_TURNING_OFF
02-06 00:23:28.647 3234 3259 D BluetoothManagerService: Sending BLE State Change: BLE_TURNING_ON > BLE_TURNING_OFF
02-06 00:23:28.647 4776 4792 D AdapterProperties: onBleDisable
02-06 00:23:28.650 4776 4776 D BtGatt.DebugUtils: handleDebugAction() action=null
02-06 00:23:28.659 4776 4776 D BluetoothAdapterService: handleMessage() - Message: 1
02-06 00:23:28.659 4776 4776 D BluetoothAdapterService: handleMessage() - MESSAGE_PROFILE_SERVICE_STATE_CHANGED
02-06 00:23:28.660 4776 4792 I AdapterState: OFF : entered
02-06 00:23:28.660 4776 4792 D AdapterProperties: Setting state to OFF
02-06 00:23:28.660 4776 4792 D BluetoothAdapterService: updateAdapterState() - Broadcasting state OFF to 1 receivers.
02-06 00:23:28.660 4776 4776 D BluetoothAdapterService: handleMessage() - Message: 3
02-06 00:23:28.660 4776 4776 D BluetoothAdapterService: handleMessage() - MESSAGE_PROFILE_SERVICE_UNREGISTERED
02-06 00:23:28.661 3234 3259 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: BLE_TURNING_OFF > OFF
02-06 00:23:28.661 3234 3259 D BluetoothManagerService: Bluetooth is complete send Service Down
02-06 00:23:28.661 3234 3259 D BluetoothManagerService: Broadcasting onBluetoothServiceDown() to 4 receivers.
02-06 00:23:28.661 3234 3259 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@12c4f53
02-06 00:23:28.661 3404 3417 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@57a2d52
02-06 00:23:28.662 3234 3259 D BluetoothManagerService: unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@12c4f53 mBinding = false mUnbinding = false
02-06 00:23:28.662 3548 3572 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@829baa2
02-06 00:23:28.662 4776 4790 D BluetoothAdapter: onBluetoothServiceDown: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@c4c11da
02-06 00:23:28.662 4776 4776 W : [0206/002328.661117:WARNING:bta_gattc_api.cc(61)] GATTC Module not enabled/already disabled
02-06 00:23:28.662 4776 4776 W : [0206/002328.662723:WARNING:bta_gatts_api.cc(56)] GATTS Module not enabled/already disabled
02-06 00:23:28.664 4776 4776 W BtGatt.ScanManager: exception when invoking removeOnUidImportanceListener
02-06 00:23:28.664 4776 4776 W BtGatt.ScanManager: java.lang.IllegalArgumentException: Listener not registered: com.android.bluetooth.gatt.ScanManager$2@df61100
02-06 00:23:28.664 4776 4776 W BtGatt.ScanManager: at android.app.ActivityManager.removeOnUidImportanceListener(ActivityManager.java:3552)
02-06 00:23:28.664 4776 4776 W BtGatt.ScanManager: at com.android.bluetooth.gatt.ScanManager.cleanup(ScanManager.java:157)
02-06 00:23:28.664 4776 4776 W BtGatt.ScanManager: at com.android.bluetooth.gatt.GattService.cleanup(GattService.java:244)
02-06 00:23:28.664 4776 4776 W BtGatt.ScanManager: at com.android.bluetooth.btservice.ProfileService.onDestroy(ProfileService.java:211)
02-06 00:23:28.664 4776 4776 W BtGatt.ScanManager: at android.app.ActivityThread.handleStopService(ActivityThread.java:3735)
02-06 00:23:28.664 4776 4776 W BtGatt.ScanManager: at android.app.ActivityThread.access$1700(ActivityThread.java:200)
02-06 00:23:28.664 4776 4776 W BtGatt.ScanManager: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1693)
02-06 00:23:28.664 4776 4776 W BtGatt.ScanManager: at android.os.Handler.dispatchMessage(Handler.java:106)
02-06 00:23:28.664 4776 4776 W BtGatt.ScanManager: at android.os.Looper.loop(Looper.java:193)
02-06 00:23:28.664 4776 4776 W BtGatt.ScanManager: at android.app.ActivityThread.main(ActivityThread.java:6718)
02-06 00:23:28.664 4776 4776 W BtGatt.ScanManager: at java.lang.reflect.Method.invoke(Native Method)
02-06 00:23:28.664 4776 4776 W BtGatt.ScanManager: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
02-06 00:23:28.664 4776 4776 W BtGatt.ScanManager: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:917)
02-06 00:23:28.665 3234 3259 D BluetoothManagerService: Sending BLE State Change: BLE_TURNING_OFF > OFF
02-06 00:23:28.665 4776 4776 W BtGatt.ScanManager: exception when invoking unregisterReceiver(mLocationReceiver)
02-06 00:23:28.665 4776 4776 W BtGatt.ScanManager: java.lang.IllegalArgumentException: Receiver not registered: com.android.bluetooth.gatt.ScanManager$3@f36d39
02-06 00:23:28.665 4776 4776 W BtGatt.ScanManager: at android.app.LoadedApk.forgetReceiverDispatcher(LoadedApk.java:1271)
02-06 00:23:28.665 4776 4776 W BtGatt.ScanManager: at android.app.ContextImpl.unregisterReceiver(ContextImpl.java:1504)
02-06 00:23:28.665 4776 4776 W BtGatt.ScanManager: at android.content.ContextWrapper.unregisterReceiver(ContextWrapper.java:659)
02-06 00:23:28.665 4776 4776 W BtGatt.ScanManager: at com.android.bluetooth.gatt.ScanManager.cleanup(ScanManager.java:178)
02-06 00:23:28.665 4776 4776 W BtGatt.ScanManager: at com.android.bluetooth.gatt.GattService.cleanup(GattService.java:244)
02-06 00:23:28.665 4776 4776 W BtGatt.ScanManager: at com.android.bluetooth.btservice.ProfileService.onDestroy(ProfileService.java:211)
02-06 00:23:28.665 4776 4776 W BtGatt.ScanManager: at android.app.ActivityThread.handleStopService(ActivityThread.java:3735)
02-06 00:23:28.665 4776 4776 W BtGatt.ScanManager: at android.app.ActivityThread.access$1700(ActivityThread.java:200)
02-06 00:23:28.665 4776 4776 W BtGatt.ScanManager: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1693)
02-06 00:23:28.665 4776 4776 W BtGatt.ScanManager: at android.os.Handler.dispatchMessage(Handler.java:106)
02-06 00:23:28.665 4776 4776 W BtGatt.ScanManager: at android.os.Looper.loop(Looper.java:193)
02-06 00:23:28.665 4776 4776 W BtGatt.ScanManager: at android.app.ActivityThread.main(ActivityThread.java:6718)
02-06 00:23:28.665 4776 4776 W BtGatt.ScanManager: at java.lang.reflect.Method.invoke(Native Method)
02-06 00:23:28.665 4776 4776 W BtGatt.ScanManager: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
02-06 00:23:28.665 4776 4776 W BtGatt.ScanManager: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:917)
02-06 00:23:28.666 4776 4776 D BluetoothAdapterService: onUnbind() - calling cleanup
02-06 00:23:28.666 4776 4776 D BluetoothAdapterService: cleanup()
02-06 00:23:28.666 3234 3259 D BluetoothManagerService: Entering STATE_OFF but mEnabled is true; restarting.
02-06 00:23:28.666 3234 3259 E BluetoothManagerService: waitForOnOff time out
02-06 00:23:28.676 4776 4776 W BluetoothSdpJni: Cleaning up Bluetooth SDP Interface...
02-06 00:23:28.677 4776 4776 W BluetoothSdpJni: Cleaning up Bluetooth SDP object
02-06 00:23:28.677 4776 4776 D BluetoothAdapterService: cleanup() - Cleaning up adapter native
02-06 00:23:29.067 3234 3259 D BluetoothManagerService: MESSAGE_RESTART_BLUETOOTH_SERVICE
02-06 00:23:29.067 3234 3259 D BluetoothManagerService: Bluetooth is dead,no more retry to restart.
02-06 00:23:29.067 3234 3259 E BluetoothManagerService: MESSAGE_TIMEOUT_BIND
02-06 00:23:29.836 3234 3346 E WifiVendorHal: getWifiLinkLayerStats(l.937) failed {.code = ERROR_NOT_AVAILABLE, .description = }
02-06 00:23:32.694 4776 4796 E bt_hci : startup_timer_expired
02-06 00:23:32.694 4776 4793 E bt_core_module: module_start_up Failed to start up module "hci_module"
02-06 00:23:32.695 4776 4813 I bt_osi_thread: run_thread: thread id 4813, thread name bt_workqueue started
02-06 00:23:32.695 4776 4813 I : [0206/002332.695891:INFO:btu_task.cc(107)] Bluetooth chip preload is complete
02-06 00:23:32.696 4776 4813 I : [0206/002332.696495:INFO:gatt_api.cc(948)] GATT_Register 81818181-8181-8181-8181-818181818181
02-06 00:23:32.696 4776 4813 I : [0206/002332.696722:INFO:gatt_api.cc(968)] allocated gatt_if=1
02-06 00:23:32.696 4776 4813 I : [0206/002332.696776:INFO:gatt_api.cc(161)] GATTS_AddService
02-06 00:23:32.696 4776 4813 I : [0206/002332.696836:INFO:gatt_api.cc(265)] GATTS_AddService: service parsed correctly, now starting
02-06 00:23:32.697 4776 4813 I : [0206/002332.697090:INFO:gatt_api.cc(948)] GATT_Register 82828282-8282-8282-8282-828282828282
02-06 00:23:32.697 4776 4813 I : [0206/002332.697147:INFO:gatt_api.cc(968)] allocated gatt_if=2
02-06 00:23:32.697 4776 4813 I : [0206/002332.697198:INFO:gatt_api.cc(161)] GATTS_AddService
02-06 00:23:32.697 4776 4813 I : [0206/002332.697257:INFO:gatt_api.cc(265)] GATTS_AddService: service parsed correctly, now starting
02-06 00:23:32.697 4776 4813 I bt_bte : BTE_InitTraceLevels -- TRC_HCI : Level 2
02-06 00:23:32.697 4776 4813 I bt_bte : BTE_InitTraceLevels -- TRC_L2CAP : Level 2
02-06 00:23:32.697 4776 4813 I bt_bte : BTE_InitTraceLevels -- TRC_RFCOMM : Level 2
02-06 00:23:32.697 4776 4813 I bt_bte : BTE_InitTraceLevels -- TRC_AVDT : Level 2
02-06 00:23:32.697 4776 4813 I bt_bte : BTE_InitTraceLevels -- TRC_AVRC : Level 2
02-06 00:23:32.697 4776 4813 I bt_bte : BTE_InitTraceLevels -- TRC_A2D : Level 2
02-06 00:23:32.697 4776 4813 I bt_bte : BTE_InitTraceLevels -- TRC_BNEP : Level 2
02-06 00:23:32.697 4776 4813 I bt_bte : BTE_InitTraceLevels -- TRC_BTM : Level 2
02-06 00:23:32.697 4776 4813 I bt_bte : BTE_InitTraceLevels -- TRC_HID_HOST : Level 2
02-06 00:23:32.697 4776 4813 I bt_bte : BTE_InitTraceLevels -- TRC_PAN : Level 2
02-06 00:23:32.697 4776 4813 I bt_bte : BTE_InitTraceLevels -- TRC_SDP : Level 2
02-06 00:23:32.698 4776 4813 I bt_bte : BTE_InitTraceLevels -- TRC_SMP : Level 2
02-06 00:23:32.698 4776 4813 I bt_bte : BTE_InitTraceLevels -- TRC_HID_DEV : Level 2
02-06 00:23:32.698 4776 4813 I bt_bte : BTE_InitTraceLevels -- TRC_BTAPP : Level 2
02-06 00:23:32.698 4776 4813 I bt_bte : BTE_InitTraceLevels -- TRC_BTIF : Level 2
02-06 00:23:32.698 4776 4814 I bt_osi_thread: run_thread: thread id 4814, thread name btu message loop started
02-06 00:23:32.700 4776 4815 I bt_osi_thread: run_thread: thread id 4815, thread name module_wrapper started
02-06 00:23:32.701 4776 4815 I bt_core_module: module_start_up Starting module "controller_module"
02-06 00:23:32.852 3234 3346 E WifiVendorHal: getWifiLinkLayerStats(l.937) failed {.code = ERROR_NOT_AVAILABLE, .description = }
02-06 00:23:34.701 4776 4796 E bt_hci : command_timed_out
02-06 00:23:34.702 4776 4796 E bt_hci : command_timed_out_log_info: 1 commands pending response
02-06 00:23:34.702 4776 4796 E bt_hci : command_timed_out_log_info: Waited 2000 ms for a response to opcode: 0xc03 *matches timer*
02-06 00:23:34.702 4776 4796 E bt_hci : command_timed_out_log_info: Size 3 Hex 03 0c 00
02-06 00:23:34.702 4776 4796 E bt_hci : command_timed_out: requesting a firmware dump.
02-06 00:23:34.703 4776 4796 E bt_hci : command_timed_out: Setting a timer to restart.
02-06 00:23:35.859 3234 3346 E WifiVendorHal: getWifiLinkLayerStats(l.937) failed {.code = ERROR_NOT_AVAILABLE, .description = }
02-06 00:23:37.138 3234 3518 D DhcpClient: Broadcasting DHCPDISCOVER
02-06 00:23:38.876 3234 3346 E WifiVendorHal: getWifiLinkLayerStats(l.937) failed {.code = ERROR_NOT_AVAILABLE, .description = }
02-06 00:23:39.703 4776 4796 E bt_hci : hci_timeout_abort restarting the Bluetooth process.
02-06 00:23:39.703 4776 4796 F libc : Fatal signal 6 (SIGABRT), code -6 (SI_TKILL) in tid 4796 (alarm_default_c), pid 4776 (droid.bluetooth)
02-06 00:23:39.787 4818 4818 I crash_dump64: obtaining output fd from tombstoned, type: kDebuggerdTombstone
02-06 00:23:39.788 3135 3135 I /system/bin/tombstoned: received crash request for pid 4796
02-06 00:23:39.800 4818 4818 I crash_dump64: performing dump of process 4776 (target tid = 4796)
02-06 00:23:39.813 4818 4818 F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
02-06 00:23:39.813 4818 4818 F DEBUG : Build fingerprint: 'Android/evk_8mm/evk_8mm:9/2.3.0-ga-rc2/cmiguel01161619:eng/dev-keys'
02-06 00:23:39.814 4818 4818 F DEBUG : Revision: '0'
02-06 00:23:39.814 4818 4818 F DEBUG : ABI: 'arm64'
02-06 00:23:39.814 4818 4818 F DEBUG : pid: 4776, tid: 4796, name: alarm_default_c >>> com.android.bluetooth <<<
02-06 00:23:39.814 4818 4818 F DEBUG : signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
02-06 00:23:39.814 4818 4818 F DEBUG : x0 0000000000000000 x1 00000000000012bc x2 0000000000000006 x3 0000000000000008
02-06 00:23:39.814 4818 4818 F DEBUG : x4 1600000000000000 x5 1600000000000000 x6 1600000000000000 x7 0000000000008016
02-06 00:23:39.814 4818 4818 F DEBUG : x8 0000000000000083 x9 0000fc83a73369a0 x10 fffffff87ffffbdf x11 0000000000000001
02-06 00:23:39.814 4818 4818 F DEBUG : x12 0000fc838a0fe608 x13 0000000000000002 x14 ffffffffffffffff x15 1600000000000000
02-06 00:23:39.814 4818 4818 F DEBUG : x16 0000fc83a736f2c8 x17 0000fc83a72ad2d8 x18 0000fc838a0fddca x19 00000000000012a8
02-06 00:23:39.814 4818 4818 F DEBUG : x20 00000000000012bc x21 0000000000000083 x22 0000fc838a0fea90 x23 0000fc838a6d7f40
02-06 00:23:39.814 4818 4818 F DEBUG : x24 000000000068efb5 x25 0000fc838a0ff588 x26 0000fc838a0fed68 x27 0000000000000001
02-06 00:23:39.814 4818 4818 F DEBUG : x28 0000000000000000 x29 0000fc838a0fea30
02-06 00:23:39.814 4818 4818 F DEBUG : sp 0000fc838a0fe9f0 lr 0000fc83a72a1a90 pc 0000fc83a72a1abc
02-06 00:23:39.835 4818 4818 F DEBUG :
02-06 00:23:39.835 4818 4818 F DEBUG : backtrace:
02-06 00:23:39.835 4818 4818 F DEBUG : #00 pc 0000000000021abc /system/lib64/libc.so (abort+124)
02-06 00:23:39.835 4818 4818 F DEBUG : #01 pc 000000000015ef74 /system/lib64/libbluetooth.so (hci_timeout_abort(void*)+52)
02-06 00:23:39.835 4818 4818 F DEBUG : #02 pc 00000000002296b8 /system/lib64/libbluetooth.so (alarm_ready_generic(alarm_t*, std::__1::unique_lock<std::__1::mutex>&)+216)
02-06 00:23:39.835 4818 4818 F DEBUG : #03 pc 00000000002295a0 /system/lib64/libbluetooth.so (alarm_queue_ready(fixed_queue_t*, void*)+112)
02-06 00:23:39.835 4818 4818 F DEBUG : #04 pc 000000000022d454 /system/lib64/libbluetooth.so (internal_dequeue_ready(void*)+84)
02-06 00:23:39.835 4818 4818 F DEBUG : #05 pc 0000000000232ee8 /system/lib64/libbluetooth.so (run_reactor(reactor_t*, int)+320)
02-06 00:23:39.835 4818 4818 F DEBUG : #06 pc 0000000000232d7c /system/lib64/libbluetooth.so (reactor_start(reactor_t*)+84)
02-06 00:23:39.836 4818 4818 F DEBUG : #07 pc 0000000000234750 /system/lib64/libbluetooth.so (run_thread(void*)+184)
02-06 00:23:39.836 4818 4818 F DEBUG : #08 pc 0000000000083114 /system/lib64/libc.so (__pthread_start(void*)+36)
02-06 00:23:39.836 4818 4818 F DEBUG : #09 pc 00000000000233bc /system/lib64/libc.so (__start_thread+68)
02-06 00:23:40.359 3135 3135 E /system/bin/tombstoned: Tombstone written to: /data/tombstones/tombstone_49
02-06 00:23:40.366 3234 3257 I BootReceiver: Copying /data/tombstones/tombstone_49 to DropBox (SYSTEM_TOMBSTONE)
02-06 00:23:40.377 3234 3251 I ActivityManager: Showing crash dialog for package com.android.bluetooth u0
02-06 00:23:40.443 3079 3079 E android.hardware.bluetooth@1.0-impl: BluetoothDeathRecipient::serviceDied - Bluetooth service died
02-06 00:23:40.443 3079 3079 I android.hardware.bluetooth@1.0-impl: BluetoothHci::close()
02-06 00:23:40.443 3079 3079 I android.hardware.bluetooth@1.0-impl: Skipping unlink call, service died.
02-06 00:23:40.443 3079 3079 I bt_userial_vendor: device fd = 6 close
02-06 00:23:40.444 3234 3246 I ActivityManager: Process com.android.bluetooth (pid 4776) has died: fore SVC
02-06 00:23:40.445 3234 3253 W libprocessgroup: kill(-4776, 9) failed: No such process
02-06 00:23:40.445 3234 3253 I libprocessgroup: Successfully killed process cgroup uid 1002 pid 4776 in 0ms
02-06 00:23:40.446 3065 3065 I Zygote : Process 4776 exited due to signal (6)
02-06 00:23:40.450 3091 3207 E display : threadLoop invalid uevent change@/devices/platform/bt_rfkill/rfkill/rfkill0
02-06 00:23:40.451 3079 3079 I android.hardware.bluetooth@1.0-impl: Firmware configured in 15.233s
02-06 00:23:40.458 3234 4408 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-06 00:23:40.458 3234 4408 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
02-06 00:23:40.458 3234 4408 I OpenGLRenderer: Initialized EGL, version 1.4
02-06 00:23:40.458 3234 4408 D OpenGLRenderer: Swap behavior 2
02-06 00:23:40.576 3234 3251 W Looper : Slow dispatch took 121ms android.ui h=android.view.Choreographer$FrameHandler c=android.view.Choreographer$FrameDisplayEventReceiver@f166d0a m=0
02-06 00:23:41.884 3234 3346 E WifiVendorHal: getWifiLinkLayerStats(l.937) failed {.code = ERROR_NOT_AVAILABLE, .description = }
02-06 00:23:44.901 3234 3346 E WifiVendorHal: getWifiLinkLayerStats(l.937) failed {.code = ERROR_NOT_AVAILABLE, .description = }
02-06 00:23:45.759 3404 3404 D InputEventConsistencyVerifier: TouchEvent: ACTION_DOWN but pointers are already down. Probably missing ACTION_UP from previous gesture.
02-06 00:23:45.759 3404 3404 D InputEventConsistencyVerifier: in android.view.ScaleGestureDetector@f7ef68c
02-06 00:23:45.759 3404 3404 D InputEventConsistencyVerifier: 0: sent at 6883162379000, MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=364.91858, y[0]=1490.2238, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=6883162, downTime=6883162, deviceId=1, source=0x1002 }
02-06 00:23:45.759 3404 3404 D InputEventConsistencyVerifier: -- recent events --
02-06 00:23:45.759 3404 3404 D InputEventConsistencyVerifier: 1: sent at 6856302451000, MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=156.11194, y[0]=156.91827, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, metaState=0, flags=0x80000000, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=6856302, downTime=6856302, deviceId=1, source=0x1002 }
02-06 00:23:45.759 3404 3404 D InputEventConsistencyVerifier: 2: sent at 6856302451000, MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=156.11194, y[0]=156.91827, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=6856302, downTime=6856302, deviceId=1, source=0x1002 }
02-06 00:23:45.948 3404 3404 D StatusBar: disable<e i a s b h r c s > disable2<q i n >
02-06 00:23:46.482 3234 3251 D AutofillManager: No AutofillClient for android on context android.app.ContextImpl@7025c77
02-06 00:23:46.524 3234 4825 W ActivityManager: Ignoring remove of inactive process: ProcessRecord{c2e56e4 0:com.android.bluetooth/1002}
02-06 00:23:46.526 3075 4286 I audio_hw_primary: start_output_stream_primary... 0xf6546000, device 2, address , mode 0
02-06 00:23:46.526 3075 4286 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 2, earpiece 0,
02-06 00:23:46.528 3234 4408 D OpenGLRenderer: endAllActiveAnimators on 0xfc837edf5000 (RippleDrawable) with handle 0xfc8382a90500
02-06 00:23:46.532 3075 4286 W audio_hw_primary: card 0, port 0 device 0x2
02-06 00:23:46.532 3075 4286 W audio_hw_primary: rate 48000, channel 2 period_size 0xc0
02-06 00:23:46.733 3098 3170 W SurfaceFlinger: Attempting to set client state on removed layer: Dim Layer for - mAboveAppWindowsContainers#0
02-06 00:23:46.734 3098 3170 W SurfaceFlinger: Attempting to destroy on removed layer: Dim Layer for - mAboveAppWindowsContainers#0
02-06 00:23:47.916 3234 3346 E WifiVendorHal: getWifiLinkLayerStats(l.937) failed {.code = ERROR_NOT_AVAILABLE, .description = }
02-06 00:23:49.701 3075 3183 W audio_hw_primary: do_out_standby... 0xf6546000
02-06 00:23:50.923 3234 3346 E WifiVendorHal: getWifiLinkLayerStats(l.937) failed {.code = ERROR_NOT_AVAILABLE, .description = }
we have escalated this issue to expert team, any update, I will forward to you ASAP
Hi joanxie,
Is there any solution?
Is there any update on this issue. I am getting same errors while using 1MW murrata module with IMX8MP. WiFi is working but while turning on bluetooth getting same errors. Below are the logs.
07-28 11:11:32.988 580 611 D BluetoothManagerService: enable(com.android.settings): mBluetooth =null mBinding = false mState = OFF
07-28 11:11:32.988 580 616 D BluetoothManagerService: MESSAGE_ENABLE(0): mBluetooth = null
07-28 11:11:32.988 580 611 D BluetoothManagerService: enable returning
07-28 11:11:32.988 580 616 D BluetoothManagerService: binding Bluetooth service
07-28 11:11:32.990 580 616 D CompatibilityChangeReporter: Compat change id reported: 135634846; UID 1002; state: DISABLED
07-28 11:11:32.991 580 616 D CompatibilityChangeReporter: Compat change id reported: 135754954; UID 1002; state: ENABLED
07-28 11:11:32.994 406 2026 I audio_hw_primary: start_output_stream: primary: 0, out: 0xec680640, device: 1024, address: , mode: 0, flags 0x0
07-28 11:11:32.994 406 2026 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 2
07-28 11:11:32.994 406 2026 D audio_hw_primary: start_output_stream: pcm_open: card: 1, pcm_device_id: 0, rate: 48000, channel: 2, format: 3, period_size: 0xc0, flag: 8
07-28 11:11:32.995 580 611 I system_server: oneway function results will be dropped but finished with status OK and parcel size 4
07-28 11:11:32.997 580 611 I system_server: oneway function results will be dropped but finished with status OK and parcel size 4
07-28 11:11:33.005 394 394 D Zygote : Forked child process 2145
07-28 11:11:33.008 580 624 I ActivityManager: Start proc 2145:com.android.bluetooth/1002 for service {com.android.bluetooth/com.android.bluetooth.btservice.AdapterService}
07-28 11:11:33.021 512 518 I adbd : jdwp connection from 2145
07-28 11:11:33.043 2145 2145 I droid.bluetoot: The ClassLoaderContext is a special shared library.
07-28 11:11:33.049 2145 2145 I droid.bluetoot: The ClassLoaderContext is a special shared library.
07-28 11:11:33.058 2145 2145 D NetworkSecurityConfig: No Network Security Config specified, using platform default
07-28 11:11:33.059 2145 2145 D NetworkSecurityConfig: No Network Security Config specified, using platform default
07-28 11:11:33.072 2145 2145 D BluetoothOppFileProvider: Initialized
07-28 11:11:33.086 2145 2145 V AdapterServiceConfig: Adding HeadsetService
07-28 11:11:33.086 2145 2145 V AdapterServiceConfig: Adding A2dpService
07-28 11:11:33.086 2145 2145 V AdapterServiceConfig: Adding HidHostService
07-28 11:11:33.086 2145 2145 V AdapterServiceConfig: Adding PanService
07-28 11:11:33.087 2145 2145 V AdapterServiceConfig: Adding GattService
07-28 11:11:33.087 2145 2145 V AdapterServiceConfig: Adding BluetoothMapService
07-28 11:11:33.087 2145 2145 V AdapterServiceConfig: Adding AvrcpTargetService
07-28 11:11:33.087 2145 2145 V AdapterServiceConfig: Adding HidDeviceService
07-28 11:11:33.087 2145 2145 V AdapterServiceConfig: Adding BluetoothOppService
07-28 11:11:33.087 2145 2145 V AdapterServiceConfig: Adding BluetoothPbapService
07-28 11:11:33.098 2145 2145 I droid.bluetoot: [0728/111133.097828:INFO:btif_config_cache.cc(61)] BtifConfigCache, capacity: 10000
07-28 11:11:33.100 2145 2145 I BluetoothServiceJni: hal_util_load_bt_library: loaded Bluetooth library successfully
07-28 11:11:33.101 2145 2145 D BluetoothAdapterService: onCreate()
07-28 11:11:33.107 2145 2145 D AdapterState: make() - Creating AdapterState
07-28 11:11:33.110 2145 2167 I AdapterState: OFF : entered
07-28 11:11:33.110 2145 2167 D AdapterProperties: Setting state to OFF
07-28 11:11:33.112 2145 2145 D BluetoothKeystoreService: new BluetoothKeystoreService isNiapMode: false
07-28 11:11:33.114 2145 2145 D BluetoothKeystoreService: start
07-28 11:11:33.115 2145 2145 I droid.bluetoot: [0728/111133.115814:INFO:com_android_bluetooth_btservice_BluetoothKeystore.cpp(97)] classInitNative: succeeds
07-28 11:11:33.116 2145 2145 D BluetoothKeystoreService: setBluetoothKeystoreService(): set to: com.android.bluetooth.btservice.bluetoothkeystore.BluetoothKeystoreService@c443418
07-28 11:11:33.117 2145 2145 D BluetoothKeystoreService: loadConfigData
07-28 11:11:33.127 2145 2145 D BluetoothKeystoreService: getCompareResult: 0
07-28 11:11:33.130 2145 2145 I bt_btif : init: start restricted = 0 ; niap = 0, config compare result = 0
07-28 11:11:33.130 2145 2145 I bt_btif : init Preserving legacy bluetooth functionality
07-28 11:11:33.130 2145 2145 D bt_osi_allocation_tracker: canary initialized
07-28 11:11:33.131 2145 2170 I droid.bluetoot: [0728/111133.131284:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_stack_manager_thread
07-28 11:11:33.131 2145 2170 I bt_stack_manager: event_init_stack is initializing the stack
07-28 11:11:33.132 2145 2170 E bt_btif_config: Config is missing adapter section
07-28 11:11:33.132 2145 2170 W bt_btif_config: init unable to load config file: /data/misc/bluedroid/bt_config.conf; using backup.
07-28 11:11:33.132 2145 2170 E droid.bluetoot: [0728/111133.132373:ERROR:config.cc(104)] config_new: unable to open file '/data/misc/bluedroid/bt_config.bak': No such file or directory
07-28 11:11:33.132 2145 2170 W bt_btif_config: init unable to load backup; attempting to transcode legacy file.
07-28 11:11:33.132 2145 2170 E bt_btif_config_transcode: btif_config_transcode unable to load XML file '/data/misc/bluedroid/bt_config.xml': 3
07-28 11:11:33.132 2145 2170 E bt_btif_config: init unable to transcode legacy file; creating empty config.
07-28 11:11:33.132 2145 2170 W droid.bluetoot: [0728/111133.132639:WARNING:btif_config.cc(186)] read_or_set_metrics_salt: Failed to read metrics salt from config
07-28 11:11:33.132 2145 2170 I droid.bluetoot: [0728/111133.132708:INFO:btif_config.cc(197)] read_or_set_metrics_salt: Metrics salt is not invalid, creating new one
07-28 11:11:33.133 2145 2173 I bt_osi_thread: run_thread: thread id 2173, thread name alarm_default_ca started
07-28 11:11:33.134 2145 2174 I bt_osi_thread: run_thread: thread id 2174, thread name alarm_dispatcher started
07-28 11:11:33.134 2145 2170 I bt_btif_core: btif_init_bluetooth entered
07-28 11:11:33.134 2145 2170 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
07-28 11:11:33.135 2145 2175 I droid.bluetoot: [0728/111133.135136:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_jni_thread
07-28 11:11:33.135 2145 2170 I bt_btif_core: btif_init_bluetooth finished
07-28 11:11:33.135 2145 2170 I bt_stack_manager: event_init_stack finished
07-28 11:11:33.135 2145 2145 I bt_osi_wakelock: wakelock_set_os_callouts set to non-native
07-28 11:11:33.135 2145 2145 I bt_btif : get_profile_interface: id = socket
07-28 11:11:33.136 2145 2175 E bt_btif_storage: btif_storage_get_adapter_property: Controller not ready! Unable to return Bluetooth Address
07-28 11:11:33.136 2145 2175 E BluetoothServiceJni: adapter_properties_callback: Status 1 is incorrect
07-28 11:11:33.137 2145 2145 D BluetoothKeystoreService: initJni()
07-28 11:11:33.137 2145 2145 I bt_btif : get_profile_interface: id = bluetooth_keystore
07-28 11:11:33.137 580 580 D BluetoothManagerService: Bluetooth Adapter name changed to iMX8
07-28 11:11:33.137 2145 2175 D AdapterProperties: Name is: iMX8
07-28 11:11:33.137 580 580 D BluetoothManagerService: Stored Bluetooth name: iMX8
07-28 11:11:33.137 2145 2175 D AdapterProperties: BT Class:5a020c
07-28 11:11:33.138 2145 2145 I bt_btif : get_profile_interface: id = sdp
07-28 11:11:33.139 2145 2145 I BluetoothAdapterService: Phone policy enabled
07-28 11:11:33.141 2145 2145 D BluetoothActiveDeviceManager: start()
07-28 11:11:33.147 421 499 W APM::AudioPolicyEngine: getDevicesForStrategy() unknown strategy: -1
07-28 11:11:33.149 580 611 I system_server: oneway function results will be dropped but finished with status OK and parcel size 4
07-28 11:11:33.149 2145 2176 D BluetoothActiveDeviceManager: onAudioDevicesAdded
07-28 11:11:33.149 2145 2176 D BluetoothActiveDeviceManager: Audio device added: EVK_8MP type: 9
07-28 11:11:33.149 2145 2176 D BluetoothActiveDeviceManager: Audio device added: EVK_8MP type: 2
07-28 11:11:33.149 2145 2176 D BluetoothActiveDeviceManager: Audio device added: EVK_8MP type: 25
07-28 11:11:33.149 2145 2176 D BluetoothActiveDeviceManager: Audio device added: EVK_8MP type: 15
07-28 11:11:33.153 2145 2145 D BluetoothDatabase: start()
07-28 11:11:33.155 2145 2145 D BluetoothDatabase: Load Database
07-28 11:11:33.178 2145 2145 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@843ce3d
07-28 11:11:33.185 2145 2145 D BluetoothAdapterService: onBind()
07-28 11:11:33.186 580 580 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-28 11:11:33.186 580 616 D BluetoothManagerService: MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-28 11:11:33.188 580 616 D BluetoothManagerService: Broadcasting onBluetoothServiceUp() to 5 receivers.
07-28 11:11:33.188 1078 1097 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@bad4be5
07-28 11:11:33.188 580 616 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@ffc5f34
07-28 11:11:33.189 1136 1155 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@90fe33f
07-28 11:11:33.189 2145 2165 D BluetoothAdapter: onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@1540f06
07-28 11:11:33.189 797 818 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@3a77853
07-28 11:11:33.190 2145 2163 D BluetoothAdapterService: enable() - Enable called with quiet mode status = false
07-28 11:11:33.190 580 616 D BluetoothManagerService: MESSAGE_GET_NAME_AND_ADDRESS
07-28 11:11:33.191 2145 2167 I AdapterState: BLE_TURNING_ON : entered
07-28 11:11:33.191 2145 2167 D AdapterProperties: Setting state to BLE_TURNING_ON
07-28 11:11:33.193 2145 2167 D BluetoothAdapterService: updateAdapterState() - Broadcasting state BLE_TURNING_ON to 1 receivers.
07-28 11:11:33.194 580 616 D BluetoothManagerService: Stored Bluetooth name: iMX8
07-28 11:11:33.194 580 616 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-28 11:11:33.194 580 616 D BluetoothManagerService: Sending BLE State Change: OFF > BLE_TURNING_ON
07-28 11:11:33.201 2145 2178 D BluetoothDatabase: compactLastConnectionTime: Compacting metadata after load
07-28 11:11:33.201 2145 2178 I BluetoothDatabase: cacheMetadata
07-28 11:11:33.203 2145 2167 D BluetoothAdapterService: bleOnProcessStart()
07-28 11:11:33.203 2145 2167 I AdapterProperties: init(), maxConnectedAudioDevices, default=5, propertyOverlayed=5, finalValue=5
07-28 11:11:33.205 2145 2167 D BluetoothAdapterService: bleOnProcessStart() - Make Bond State Machine
07-28 11:11:33.206 2145 2167 D BluetoothBondStateMachine: make
07-28 11:11:33.207 2145 2183 I BluetoothBondStateMachine: StableState(): Entering Off State
07-28 11:11:33.219 2145 2145 I BtGatt.JNI: classInitNative(L875): classInitNative: Success!
07-28 11:11:33.221 2145 2145 D BtGatt.DebugUtils: handleDebugAction() action=null
07-28 11:11:33.222 2145 2145 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@843ce3d
07-28 11:11:33.224 2145 2145 I bt_btif : get_profile_interface: id = gatt
07-28 11:11:33.227 2145 2145 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@843ce3d
07-28 11:11:33.235 2145 2145 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@843ce3d
07-28 11:11:33.236 2145 2170 I bt_stack_manager: event_start_up_stack is bringing up the stack
07-28 11:11:33.237 2145 2170 I bt_core_module: module_start_up Starting module "btif_config_module"
07-28 11:11:33.237 2145 2170 I bt_core_module: module_start_up Started module "btif_config_module"
07-28 11:11:33.237 2145 2170 I bt_core_module: module_start_up Starting module "btsnoop_module"
07-28 11:11:33.237 2145 2170 I droid.bluetoot: [0728/111133.237369:INFO:btsnoop.cc(207)] start_up: Snoop Logs disabled
07-28 11:11:33.237 2145 2170 I droid.bluetoot: [0728/111133.237459:INFO:btsnoop.cc(338)] delete_btsnoop_files: Deleting snoop logs if they exist. filtered = 1
07-28 11:11:33.237 2145 2170 I droid.bluetoot: [0728/111133.237627:INFO:btsnoop.cc(338)] delete_btsnoop_files: Deleting snoop logs if they exist. filtered = 0
07-28 11:11:33.237 2145 2170 I bt_core_module: module_start_up Started module "btsnoop_module"
07-28 11:11:33.237 2145 2170 I bt_core_module: module_start_up Starting module "hci_module"
07-28 11:11:33.237 2145 2170 I bt_hci : hci_module_start_up
07-28 11:11:33.238 2145 2188 I droid.bluetoot: [0728/111133.238344:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_hci_thread
07-28 11:11:33.238 2145 2188 I bt_hci : hci_initialize
07-28 11:11:33.239 2145 2170 D bt_hci : hci_module_start_up starting async portion
07-28 11:11:33.239 250 250 I hwservicemanager: getTransport: Cannot find entry android.hardware.bluetooth@1.1::IBluetoothHci/default in either framework or device manifest.
07-28 11:11:33.240 2145 2188 I bt_hci : hci_initialize: IBluetoothHci::getService() returned 0xb400007acfee68f0 (remote)
07-28 11:11:33.241 407 407 I android.hardware.bluetooth@1.0-impl: BluetoothHci::initialize()
07-28 11:11:33.245 407 407 I bt_vendor: init
07-28 11:11:33.245 407 407 I bt_vnd_conf: Attempt to load conf from /vendor/etc/bluetooth/bt_vendor.conf
07-28 11:11:33.247 407 407 D android.hardware.bluetooth@1.0-impl: Open vendor library loaded
07-28 11:11:33.248 407 407 W bt_vendor: NOTE: BT_VND_PWR_ON now forces power-off first
07-28 11:11:33.248 407 407 I bt_userial_vendor: userial vendor open: opening /dev/ttymxc0
07-28 11:11:33.298 407 407 I bt_userial_vendor: device fd = 6 open
07-28 11:11:36.134 406 446 W audio_hw_primary: do_out_standby... 0xec680640
07-28 11:11:36.135 580 611 I system_server: oneway function results will be dropped but finished with status OK and parcel size 4
07-28 11:11:37.207 2145 2167 E AdapterState: BLE_TURNING_ON : BLE_START_TIMEOUT
07-28 11:11:37.208 2145 2167 I AdapterState: BLE_TURNING_OFF : entered
07-28 11:11:37.208 2145 2167 D AdapterProperties: Setting state to BLE_TURNING_OFF
07-28 11:11:37.208 2145 2167 D BluetoothAdapterService: updateAdapterState() - Broadcasting state BLE_TURNING_OFF to 1 receivers.
07-28 11:11:37.209 580 616 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: BLE_TURNING_ON > BLE_TURNING_OFF
07-28 11:11:37.209 580 616 D BluetoothManagerService: Sending BLE State Change: BLE_TURNING_ON > BLE_TURNING_OFF
07-28 11:11:37.209 2145 2167 D AdapterProperties: onBleDisable
07-28 11:11:37.211 2145 2145 D BtGatt.DebugUtils: handleDebugAction() action=null
07-28 11:11:37.215 2145 2145 W droid.bluetoot: [0728/111137.215175:WARNING:bta_gattc_api.cc(61)] GATTC Module not enabled/already disabled
07-28 11:11:37.215 2145 2145 W droid.bluetoot: [0728/111137.215397:WARNING:bta_gatts_api.cc(56)] GATTS Module not enabled/already disabled
07-28 11:11:37.216 2145 2145 W BtGatt.ScanManager: exception when invoking removeOnUidImportanceListener
07-28 11:11:37.216 2145 2145 W BtGatt.ScanManager: java.lang.IllegalArgumentException: Listener not registered: com.android.bluetooth.gatt.ScanManager$2@bc6c4ea
07-28 11:11:37.216 2145 2145 W BtGatt.ScanManager: at android.app.ActivityManager.removeOnUidImportanceListener(ActivityManager.java:3863)
07-28 11:11:37.216 2145 2145 W BtGatt.ScanManager: at com.android.bluetooth.gatt.ScanManager.cleanup(ScanManager.java:157)
07-28 11:11:37.216 2145 2145 W BtGatt.ScanManager: at com.android.bluetooth.gatt.GattService.cleanup(GattService.java:266)
07-28 11:11:37.216 2145 2145 W BtGatt.ScanManager: at com.android.bluetooth.btservice.ProfileService.onDestroy(ProfileService.java:211)
07-28 11:11:37.216 2145 2145 W BtGatt.ScanManager: at android.app.ActivityThread.handleStopService(ActivityThread.java:4349)
07-28 11:11:37.216 2145 2145 W BtGatt.ScanManager: at android.app.ActivityThread.access$1900(ActivityThread.java:237)
07-28 11:11:37.216 2145 2145 W BtGatt.ScanManager: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1956)
07-28 11:11:37.216 2145 2145 W BtGatt.ScanManager: at android.os.Handler.dispatchMessage(Handler.java:106)
07-28 11:11:37.216 2145 2145 W BtGatt.ScanManager: at android.os.Looper.loop(Looper.java:223)
07-28 11:11:37.216 2145 2145 W BtGatt.ScanManager: at android.app.ActivityThread.main(ActivityThread.java:7660)
07-28 11:11:37.216 2145 2145 W BtGatt.ScanManager: at java.lang.reflect.Method.invoke(Native Method)
07-28 11:11:37.216 2145 2145 W BtGatt.ScanManager: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:592)
07-28 11:11:37.216 2145 2145 W BtGatt.ScanManager: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:947)
07-28 11:11:37.217 2145 2145 W BtGatt.ScanManager: exception when invoking unregisterReceiver(mLocationReceiver)
07-28 11:11:37.217 2145 2145 W BtGatt.ScanManager: java.lang.IllegalArgumentException: Receiver not registered: com.android.bluetooth.gatt.ScanManager$3@a9d53db
07-28 11:11:37.217 2145 2145 W BtGatt.ScanManager: at android.app.LoadedApk.forgetReceiverDispatcher(LoadedApk.java:1459)
07-28 11:11:37.217 2145 2145 W BtGatt.ScanManager: at android.app.ContextImpl.unregisterReceiver(ContextImpl.java:1642)
07-28 11:11:37.217 2145 2145 W BtGatt.ScanManager: at android.content.ContextWrapper.unregisterReceiver(ContextWrapper.java:715)
07-28 11:11:37.217 2145 2145 W BtGatt.ScanManager: at com.android.bluetooth.gatt.ScanManager.cleanup(ScanManager.java:178)
07-28 11:11:37.217 2145 2145 W BtGatt.ScanManager: at com.android.bluetooth.gatt.GattService.cleanup(GattService.java:266)
07-28 11:11:37.217 2145 2145 W BtGatt.ScanManager: at com.android.bluetooth.btservice.ProfileService.onDestroy(ProfileService.java:211)
07-28 11:11:37.217 2145 2145 W BtGatt.ScanManager: at android.app.ActivityThread.handleStopService(ActivityThread.java:4349)
07-28 11:11:37.217 2145 2145 W BtGatt.ScanManager: at android.app.ActivityThread.access$1900(ActivityThread.java:237)
07-28 11:11:37.217 2145 2145 W BtGatt.ScanManager: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1956)
07-28 11:11:37.217 2145 2145 W BtGatt.ScanManager: at android.os.Handler.dispatchMessage(Handler.java:106)
07-28 11:11:37.217 2145 2145 W BtGatt.ScanManager: at android.os.Looper.loop(Looper.java:223)
07-28 11:11:37.217 2145 2145 W BtGatt.ScanManager: at android.app.ActivityThread.main(ActivityThread.java:7660)
07-28 11:11:37.217 2145 2145 W BtGatt.ScanManager: at java.lang.reflect.Method.invoke(Native Method)
07-28 11:11:37.217 2145 2145 W BtGatt.ScanManager: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:592)
07-28 11:11:37.217 2145 2145 W BtGatt.ScanManager: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:947)
07-28 11:11:37.271 580 614 I ActivityManager: Killing 1633:android.process.acore/u0a67 (adj 985): empty #17
07-28 11:11:37.295 580 866 D CountryDetector: No listener is left
07-28 11:11:37.296 394 394 I Zygote : Process 1633 exited due to signal 9 (Killed)
07-28 11:11:37.317 580 625 I libprocessgroup: Successfully killed process cgroup uid 10067 pid 1633 in 45ms
07-28 11:11:38.210 2145 2167 E AdapterState: BLE_TURNING_OFF : BLE_STOP_TIMEOUT
07-28 11:11:38.210 2145 2167 I AdapterState: OFF : entered
07-28 11:11:38.210 2145 2167 D AdapterProperties: Setting state to OFF
07-28 11:11:38.211 2145 2167 D BluetoothAdapterService: updateAdapterState() - Broadcasting state OFF to 1 receivers.
07-28 11:11:38.211 580 616 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: BLE_TURNING_OFF > OFF
07-28 11:11:38.211 580 616 D BluetoothManagerService: Bluetooth is complete send Service Down
07-28 11:11:38.211 580 616 D BluetoothManagerService: Broadcasting onBluetoothServiceDown() to 5 receivers.
07-28 11:11:38.212 1078 1097 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@bad4be5
07-28 11:11:38.212 580 616 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@ffc5f34
07-28 11:11:38.212 1136 1155 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@90fe33f
07-28 11:11:38.212 580 616 D BluetoothManagerService: unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@ffc5f34 mBinding = false mUnbinding = false
07-28 11:11:38.212 797 818 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@3a77853
07-28 11:11:38.212 2145 2163 D BluetoothAdapter: onBluetoothServiceDown: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@1540f06
07-28 11:11:38.214 2145 2145 D BluetoothAdapterService: onUnbind() - calling cleanup
07-28 11:11:38.215 2145 2145 D BluetoothAdapterService: cleanup()
07-28 11:11:38.216 580 616 D BluetoothManagerService: Sending BLE State Change: BLE_TURNING_OFF > OFF
07-28 11:11:38.216 580 616 D BluetoothManagerService: Entering STATE_OFF but mEnabled is true; restarting.
07-28 11:11:38.217 580 616 E BluetoothManagerService: waitForState [10] time out
07-28 11:11:38.221 2145 2145 W BluetoothSdpJni: Cleaning up Bluetooth SDP Interface...
07-28 11:11:38.221 2145 2145 W BluetoothSdpJni: Cleaning up Bluetooth SDP object
07-28 11:11:38.221 2145 2145 D BluetoothKeystoreService: cleanup
07-28 11:11:38.221 2145 2145 D BluetoothKeystoreService: setBluetoothKeystoreService(): set to: null
07-28 11:11:38.221 2145 2145 D BluetoothAdapterService: cleanup() - Cleaning up adapter native
07-28 11:11:38.617 580 616 D BluetoothManagerService: MESSAGE_RESTART_BLUETOOTH_SERVICE: retry count=1
07-28 11:11:38.617 580 616 D BluetoothManagerService: binding Bluetooth service
07-28 11:11:41.238 2145 2173 E bt_hci : startup_timer_expired
07-28 11:11:41.238 407 407 I android.hardware.bluetooth@1.0-impl: BluetoothHci::close()
07-28 11:11:41.239 407 407 I bt_userial_vendor: device fd = 6 close
07-28 11:11:41.241 407 407 I android.hardware.bluetooth@1.0-impl: Firmware configured in 7.943s
07-28 11:11:41.242 2145 2173 F libc : Fatal signal 6 (SIGABRT), code -1 (SI_QUEUE) in tid 2173 (alarm_default_c), pid 2145 (droid.bluetooth)
07-28 11:11:41.321 2193 2193 I crash_dump64: obtaining output fd from tombstoned, type: kDebuggerdTombstone
07-28 11:11:41.323 387 387 I tombstoned: received crash request for pid 2173
07-28 11:11:41.324 2193 2193 I crash_dump64: performing dump of process 2145 (target tid = 2173)
07-28 11:11:41.339 2193 2193 F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-28 11:11:41.340 2193 2193 F DEBUG : Build fingerprint: 'Android/evk_8mp/evk_8mp:11/RQ2A.210305.006/eng.admin.20210715.105116:userdebug/dev-keys'
07-28 11:11:41.340 2193 2193 F DEBUG : Revision: '0'
07-28 11:11:41.340 2193 2193 F DEBUG : ABI: 'arm64'
07-28 11:11:41.340 2193 2193 F DEBUG : Timestamp: 2021-07-28 11:11:41+0000
07-28 11:11:41.340 2193 2193 F DEBUG : pid: 2145, tid: 2173, name: alarm_default_c >>> com.android.bluetooth <<<
07-28 11:11:41.340 2193 2193 F DEBUG : uid: 1002
07-28 11:11:41.340 2193 2193 F DEBUG : signal 6 (SIGABRT), code -1 (SI_QUEUE), fault addr --------
07-28 11:11:41.340 2193 2193 F DEBUG : x0 0000000000000000 x1 000000000000087d x2 0000000000000006 x3 00000079b2139fe0
07-28 11:11:41.341 2193 2193 F DEBUG : x4 b400007affef7c00 x5 b400007affef7c00 x6 b400007affef7c00 x7 00000079b2139d79
07-28 11:11:41.341 2193 2193 F DEBUG : x8 00000000000000f0 x9 0000007c303fb7e0 x10 ffffff80fffffbdf x11 0000000000000001
07-28 11:11:41.341 2193 2193 F DEBUG : x12 0000000000000000 x13 0000000000000017 x14 00000079b213a0a4 x15 0000000034b30b70
07-28 11:11:41.341 2193 2193 F DEBUG : x16 0000007c30494c80 x17 0000007c304763c0 x18 00000079b1a7c038 x19 00000000000000ac
07-28 11:11:41.341 2193 2193 F DEBUG : x20 0000000000000861 x21 00000000000000b2 x22 000000000000087d x23 00000000ffffffff
07-28 11:11:41.341 2193 2193 F DEBUG : x24 00000079b213b000 x25 00000079b67e6350 x26 0000000000019218 x27 0000000000000000
07-28 11:11:41.341 2193 2193 F DEBUG : x28 0000000000000010 x29 00000079b213a060
07-28 11:11:41.341 2193 2193 F DEBUG : lr 0000007c30429544 sp 00000079b2139fc0 pc 0000007c30429574 pst 0000000000000000
07-28 11:11:41.406 2193 2193 F DEBUG : backtrace:
07-28 11:11:41.406 2193 2193 F DEBUG : #00 pc 000000000004e574 /apex/com.android.runtime/lib64/bionic/libc.so (abort+180) (BuildId: 2338ca8a340db969666f0073f3371d96)
07-28 11:11:41.406 2193 2193 F DEBUG : #01 pc 000000000026540c /system/lib64/libbluetooth.so (startup_timer_expired(void*)+188) (BuildId: f36034c2375aa79d14eb8021f2b0fb2b)
07-28 11:11:41.406 2193 2193 F DEBUG : #02 pc 00000000003371e8 /system/lib64/libbluetooth.so (alarm_ready_generic(alarm_t*, std::__1::unique_lock<std::__1::mutex>&)+400) (BuildId: f36034c2375aa79d14eb8021f2b0fb2b)
07-28 11:11:41.406 2193 2193 F DEBUG : #03 pc 0000000000337018 /system/lib64/libbluetooth.so (alarm_queue_ready(fixed_queue_t*, void*)+112) (BuildId: f36034c2375aa79d14eb8021f2b0fb2b)
07-28 11:11:41.406 2193 2193 F DEBUG : #04 pc 000000000033c430 /system/lib64/libbluetooth.so (internal_dequeue_ready(void*)+88) (BuildId: f36034c2375aa79d14eb8021f2b0fb2b)
07-28 11:11:41.406 2193 2193 F DEBUG : #05 pc 000000000033dab4 /system/lib64/libbluetooth.so (run_reactor(reactor_t*, int)+388) (BuildId: f36034c2375aa79d14eb8021f2b0fb2b)
07-28 11:11:41.406 2193 2193 F DEBUG : #06 pc 000000000033d900 /system/lib64/libbluetooth.so (reactor_start(reactor_t*)+88) (BuildId: f36034c2375aa79d14eb8021f2b0fb2b)
07-28 11:11:41.406 2193 2193 F DEBUG : #07 pc 000000000033f428 /system/lib64/libbluetooth.so (run_thread(void*)+184) (BuildId: f36034c2375aa79d14eb8021f2b0fb2b)
07-28 11:11:41.406 2193 2193 F DEBUG : #08 pc 00000000000b0c08 /apex/com.android.runtime/lib64/bionic/libc.so (__pthread_start(void*)+64) (BuildId: 2338ca8a340db969666f0073f3371d96)
07-28 11:11:41.407 2193 2193 F DEBUG : #09 pc 00000000000505d0 /apex/com.android.runtime/lib64/bionic/libc.so (__start_thread+64) (BuildId: 2338ca8a340db969666f0073f3371d96)
07-28 11:11:41.620 580 616 E BluetoothManagerService: MESSAGE_TIMEOUT_BIND
07-28 11:11:41.670 0 0 D [ T260] logd: logdr: UID=1002 GID=1002 PID=2193 n tail=50 logMask=8 pid=2145 start=0ns timeout=0ns
07-28 11:11:41.673 0 0 D [ T260] logd: logdr: UID=1002 GID=1002 PID=2193 n tail=50 logMask=1 pid=2145 start=0ns timeout=0ns
07-28 11:11:42.035 0 0 D [ T260] logd: logdr: UID=1002 GID=1002 PID=2193 n tail=0 logMask=8 pid=2145 start=0ns timeout=0ns
07-28 11:11:42.038 0 0 D [ T260] logd: logdr: UID=1002 GID=1002 PID=2193 n tail=0 logMask=1 pid=2145 start=0ns timeout=0ns
07-28 11:11:42.044 387 387 E tombstoned: Tombstone written to: /data/tombstones/tombstone_00
07-28 11:11:42.046 580 2201 I DropBoxManagerService: add tag=system_app_native_crash isTagEnabled=true flags=0x2
07-28 11:11:42.049 580 630 I BootReceiver: Copying /data/tombstones/tombstone_00 to DropBox (SYSTEM_TOMBSTONE)
07-28 11:11:42.051 580 630 I DropBoxManagerService: add tag=SYSTEM_TOMBSTONE isTagEnabled=true flags=0x2
07-28 11:11:42.078 0 0 I [ T1] init: Untracked pid 2193 exited with status 0
07-28 11:11:42.086 0 0 I [ T1] init: Untracked pid 2195 exited with status 0
07-28 11:11:42.102 580 866 I ActivityManager: Process com.android.bluetooth (pid 2145) has died: psvc PER
07-28 11:11:42.103 580 866 W ActivityManager: Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms for connection
07-28 11:11:42.103 394 394 I Zygote : Process 2145 exited due to signal 6 (Aborted)
07-28 11:11:42.146 580 625 I libprocessgroup: Successfully killed process cgroup uid 1002 pid 2145 in 43ms
07-28 11:11:42.310 580 866 I ActivityManager: Killing 1736:com.android.calendar/u0a112 (adj 975): empty #17
07-28 11:11:42.329 394 394 I Zygote : Process 1736 exited due to signal 9 (Killed)
07-28 11:11:42.342 580 625 I libprocessgroup: Successfully killed process cgroup uid 10112 pid 1736 in 31ms
07-28 11:11:43.106 580 623 D CompatibilityChangeReporter: Compat change id reported: 135634846; UID 1002; state: DISABLED
07-28 11:11:43.106 580 623 D CompatibilityChangeReporter: Compat change id reported: 135754954; UID 1002; state: ENABLED
07-28 11:11:43.119 394 394 D Zygote : Forked child process 2203
07-28 11:11:43.124 580 624 I ActivityManager: Start proc 2203:com.android.bluetooth/1002 for service {com.android.bluetooth/com.android.bluetooth.btservice.AdapterService}
07-28 11:11:43.133 512 518 I adbd : jdwp connection from 2203
07-28 11:11:43.154 2203 2203 I droid.bluetoot: The ClassLoaderContext is a special shared library.
07-28 11:11:43.158 2203 2203 I droid.bluetoot: The ClassLoaderContext is a special shared library.
07-28 11:11:43.168 2203 2203 D NetworkSecurityConfig: No Network Security Config specified, using platform default
07-28 11:11:43.179 2203 2203 D BluetoothOppFileProvider: Initialized
07-28 11:11:43.193 2203 2203 V AdapterServiceConfig: Adding HeadsetService
07-28 11:11:43.194 2203 2203 V AdapterServiceConfig: Adding A2dpService
07-28 11:11:43.194 2203 2203 V AdapterServiceConfig: Adding HidHostService
07-28 11:11:43.194 2203 2203 V AdapterServiceConfig: Adding PanService
07-28 11:11:43.194 2203 2203 V AdapterServiceConfig: Adding GattService
07-28 11:11:43.194 2203 2203 V AdapterServiceConfig: Adding BluetoothMapService
07-28 11:11:43.194 2203 2203 V AdapterServiceConfig: Adding AvrcpTargetService
07-28 11:11:43.194 2203 2203 V AdapterServiceConfig: Adding HidDeviceService
07-28 11:11:43.194 2203 2203 V AdapterServiceConfig: Adding BluetoothOppService
07-28 11:11:43.194 2203 2203 V AdapterServiceConfig: Adding BluetoothPbapService
07-28 11:11:43.203 2203 2203 I droid.bluetoot: [0728/111143.202681:INFO:btif_config_cache.cc(61)] BtifConfigCache, capacity: 10000
07-28 11:11:43.205 2203 2203 I BluetoothServiceJni: hal_util_load_bt_library: loaded Bluetooth library successfully
07-28 11:11:43.206 2203 2203 D BluetoothAdapterService: onCreate()
07-28 11:11:43.212 2203 2203 D AdapterState: make() - Creating AdapterState
07-28 11:11:43.213 2203 2225 I AdapterState: OFF : entered
07-28 11:11:43.214 2203 2225 D AdapterProperties: Setting state to OFF
07-28 11:11:43.215 2203 2203 D BluetoothKeystoreService: new BluetoothKeystoreService isNiapMode: false
07-28 11:11:43.216 2203 2203 D BluetoothKeystoreService: start
07-28 11:11:43.217 2203 2203 I droid.bluetoot: [0728/111143.217331:INFO:com_android_bluetooth_btservice_BluetoothKeystore.cpp(97)] classInitNative: succeeds
07-28 11:11:43.217 2203 2203 D BluetoothKeystoreService: setBluetoothKeystoreService(): set to: com.android.bluetooth.btservice.bluetoothkeystore.BluetoothKeystoreService@c443418
07-28 11:11:43.219 2203 2203 D BluetoothKeystoreService: loadConfigData
07-28 11:11:43.228 2203 2203 D BluetoothKeystoreService: getCompareResult: 0
07-28 11:11:43.229 2203 2203 I bt_btif : init: start restricted = 0 ; niap = 0, config compare result = 0
07-28 11:11:43.229 2203 2203 I bt_btif : init Preserving legacy bluetooth functionality
07-28 11:11:43.230 2203 2203 D bt_osi_allocation_tracker: canary initialized
07-28 11:11:43.230 2203 2228 I droid.bluetoot: [0728/111143.230388:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_stack_manager_thread
07-28 11:11:43.230 2203 2228 I bt_stack_manager: event_init_stack is initializing the stack
07-28 11:11:43.231 2203 2228 E bt_btif_config: Config is missing adapter section
07-28 11:11:43.231 2203 2228 W bt_btif_config: init unable to load config file: /data/misc/bluedroid/bt_config.conf; using backup.
07-28 11:11:43.231 2203 2228 E droid.bluetoot: [0728/111143.231368:ERROR:config.cc(104)] config_new: unable to open file '/data/misc/bluedroid/bt_config.bak': No such file or directory
07-28 11:11:43.231 2203 2228 W bt_btif_config: init unable to load backup; attempting to transcode legacy file.
07-28 11:11:43.231 2203 2228 E bt_btif_config_transcode: btif_config_transcode unable to load XML file '/data/misc/bluedroid/bt_config.xml': 3
07-28 11:11:43.231 2203 2228 E bt_btif_config: init unable to transcode legacy file; creating empty config.
07-28 11:11:43.231 2203 2228 W droid.bluetoot: [0728/111143.231676:WARNING:btif_config.cc(186)] read_or_set_metrics_salt: Failed to read metrics salt from config
07-28 11:11:43.231 2203 2228 I droid.bluetoot: [0728/111143.231750:INFO:btif_config.cc(197)] read_or_set_metrics_salt: Metrics salt is not invalid, creating new one
07-28 11:11:43.232 2203 2231 I bt_osi_thread: run_thread: thread id 2231, thread name alarm_default_ca started
07-28 11:11:43.232 2203 2232 I bt_osi_thread: run_thread: thread id 2232, thread name alarm_dispatcher started
07-28 11:11:43.233 2203 2228 I bt_btif_core: btif_init_bluetooth entered
07-28 11:11:43.233 2203 2228 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
07-28 11:11:43.234 2203 2233 I droid.bluetoot: [0728/111143.233958:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_jni_thread
07-28 11:11:43.234 2203 2228 I bt_btif_core: btif_init_bluetooth finished
07-28 11:11:43.234 2203 2228 I bt_stack_manager: event_init_stack finished
07-28 11:11:43.234 2203 2203 I bt_osi_wakelock: wakelock_set_os_callouts set to non-native
07-28 11:11:43.234 2203 2203 I bt_btif : get_profile_interface: id = socket
07-28 11:11:43.234 2203 2233 E bt_btif_storage: btif_storage_get_adapter_property: Controller not ready! Unable to return Bluetooth Address
07-28 11:11:43.234 2203 2233 E BluetoothServiceJni: adapter_properties_callback: Status 1 is incorrect
07-28 11:11:43.235 2203 2203 D BluetoothKeystoreService: initJni()
07-28 11:11:43.235 2203 2203 I bt_btif : get_profile_interface: id = bluetooth_keystore
07-28 11:11:43.236 580 580 D BluetoothManagerService: Bluetooth Adapter name changed to iMX8
07-28 11:11:43.236 2203 2203 I bt_btif : get_profile_interface: id = sdp
07-28 11:11:43.236 580 580 D BluetoothManagerService: Stored Bluetooth name: iMX8
07-28 11:11:43.236 2203 2233 D AdapterProperties: Name is: iMX8
07-28 11:11:43.236 2203 2233 D AdapterProperties: BT Class:5a020c
07-28 11:11:43.237 2203 2203 I BluetoothAdapterService: Phone policy enabled
07-28 11:11:43.239 2203 2203 D BluetoothActiveDeviceManager: start()
07-28 11:11:43.243 2203 2234 D BluetoothActiveDeviceManager: onAudioDevicesAdded
07-28 11:11:43.244 2203 2234 D BluetoothActiveDeviceManager: Audio device added: EVK_8MP type: 9
07-28 11:11:43.244 2203 2234 D BluetoothActiveDeviceManager: Audio device added: EVK_8MP type: 2
07-28 11:11:43.244 2203 2234 D BluetoothActiveDeviceManager: Audio device added: EVK_8MP type: 25
07-28 11:11:43.244 2203 2234 D BluetoothActiveDeviceManager: Audio device added: EVK_8MP type: 15
07-28 11:11:43.247 2203 2203 D BluetoothDatabase: start()
07-28 11:11:43.249 2203 2203 D BluetoothDatabase: Load Database
07-28 11:11:43.260 2203 2203 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@843ce3d
07-28 11:11:43.266 2203 2203 D BluetoothAdapterService: onBind()
07-28 11:11:43.266 580 580 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-28 11:11:43.267 580 616 D BluetoothManagerService: MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-28 11:11:43.268 580 616 D BluetoothManagerService: Broadcasting onBluetoothServiceUp() to 5 receivers.
07-28 11:11:43.268 797 818 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@829b590
07-28 11:11:43.268 580 616 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@7923992
07-28 11:11:43.268 1136 1155 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@4bb240c
07-28 11:11:43.269 1078 1097 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@e0746ba
07-28 11:11:43.269 2203 2223 D BluetoothAdapter: onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@1540f06
07-28 11:11:43.270 2203 2222 D BluetoothAdapterService: enable() - Enable called with quiet mode status = false
07-28 11:11:43.270 580 616 D BluetoothManagerService: MESSAGE_GET_NAME_AND_ADDRESS
07-28 11:11:43.270 2203 2225 I AdapterState: BLE_TURNING_ON : entered
07-28 11:11:43.270 2203 2225 D AdapterProperties: Setting state to BLE_TURNING_ON
07-28 11:11:43.271 2203 2225 D BluetoothAdapterService: updateAdapterState() - Broadcasting state BLE_TURNING_ON to 1 receivers.
07-28 11:11:43.273 580 616 D BluetoothManagerService: Stored Bluetooth name: iMX8
07-28 11:11:43.273 580 616 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-28 11:11:43.273 580 616 D BluetoothManagerService: Sending BLE State Change: OFF > BLE_TURNING_ON
07-28 11:11:43.276 2203 2236 D BluetoothDatabase: compactLastConnectionTime: Compacting metadata after load
07-28 11:11:43.276 2203 2236 I BluetoothDatabase: cacheMetadata
07-28 11:11:43.282 2203 2225 D BluetoothAdapterService: bleOnProcessStart()
07-28 11:11:43.282 2203 2225 I AdapterProperties: init(), maxConnectedAudioDevices, default=5, propertyOverlayed=5, finalValue=5
07-28 11:11:43.284 2203 2225 D BluetoothAdapterService: bleOnProcessStart() - Make Bond State Machine
07-28 11:11:43.285 2203 2225 D BluetoothBondStateMachine: make
07-28 11:11:43.286 2203 2241 I BluetoothBondStateMachine: StableState(): Entering Off State
07-28 11:11:43.297 2203 2203 I BtGatt.JNI: classInitNative(L875): classInitNative: Success!
07-28 11:11:43.299 2203 2203 D BtGatt.DebugUtils: handleDebugAction() action=null
07-28 11:11:43.300 2203 2203 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@843ce3d
07-28 11:11:43.302 2203 2203 I bt_btif : get_profile_interface: id = gatt
07-28 11:11:43.303 2203 2203 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@843ce3d
07-28 11:11:43.308 2203 2203 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@843ce3d
07-28 11:11:43.310 2203 2228 I bt_stack_manager: event_start_up_stack is bringing up the stack
07-28 11:11:43.310 2203 2228 I bt_core_module: module_start_up Starting module "btif_config_module"
07-28 11:11:43.310 2203 2228 I bt_core_module: module_start_up Started module "btif_config_module"
07-28 11:11:43.310 2203 2228 I bt_core_module: module_start_up Starting module "btsnoop_module"
07-28 11:11:43.310 2203 2228 I droid.bluetoot: [0728/111143.310573:INFO:btsnoop.cc(207)] start_up: Snoop Logs disabled
07-28 11:11:43.310 2203 2228 I droid.bluetoot: [0728/111143.310675:INFO:btsnoop.cc(338)] delete_btsnoop_files: Deleting snoop logs if they exist. filtered = 1
07-28 11:11:43.310 2203 2228 I droid.bluetoot: [0728/111143.310804:INFO:btsnoop.cc(338)] delete_btsnoop_files: Deleting snoop logs if they exist. filtered = 0
07-28 11:11:43.310 2203 2228 I bt_core_module: module_start_up Started module "btsnoop_module"
07-28 11:11:43.311 2203 2228 I bt_core_module: module_start_up Starting module "hci_module"
07-28 11:11:43.311 2203 2228 I bt_hci : hci_module_start_up
07-28 11:11:43.311 2203 2246 I droid.bluetoot: [0728/111143.311671:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_hci_thread
07-28 11:11:43.312 2203 2246 I bt_hci : hci_initialize
07-28 11:11:43.312 2203 2228 D bt_hci : hci_module_start_up starting async portion
07-28 11:11:43.313 250 250 I hwservicemanager: getTransport: Cannot find entry android.hardware.bluetooth@1.1::IBluetoothHci/default in either framework or device manifest.
07-28 11:11:43.315 2203 2246 I bt_hci : hci_initialize: IBluetoothHci::getService() returned 0xb400007acfee68f0 (remote)
07-28 11:11:43.315 407 407 I android.hardware.bluetooth@1.0-impl: BluetoothHci::initialize()
07-28 11:11:43.316 407 407 I bt_vendor: init
07-28 11:11:43.316 407 407 I bt_vnd_conf: Attempt to load conf from /vendor/etc/bluetooth/bt_vendor.conf
07-28 11:11:43.316 407 407 D android.hardware.bluetooth@1.0-impl: Open vendor library loaded
07-28 11:11:43.316 407 407 W bt_vendor: NOTE: BT_VND_PWR_ON now forces power-off first
07-28 11:11:43.316 407 407 I bt_userial_vendor: userial vendor open: opening /dev/ttymxc0
07-28 11:11:43.366 407 407 I bt_userial_vendor: device fd = 6 open
07-28 11:11:47.135 580 732 E WifiScoringParams: Invalid frequency(-1), using 5G as default rssi array
07-28 11:11:47.147 580 2249 I system_server: The ClassLoaderContext is a special shared library.
07-28 11:11:47.150 0 0 E [ T409] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sleep state -110
07-28 11:11:47.158 0 0 E [ T409] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
07-28 11:11:47.167 0 0 I chatty : uid=0(root) logd identical 1 line
07-28 11:11:47.176 0 0 E [ T409] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
07-28 11:11:47.185 0 0 E [ T409] brcmfmac: brcmf_sdio_dpc: sdio ctrlframe tx failed err=-110
07-28 11:11:47.193 0 0 E [ T409] brcmfmac: brcmf_sdio_dpc: failed backplane access over SDIO, halting operation
07-28 11:11:47.193 0 0 E : [ T487] ieee80211 phy0: brcmf_run_escan: error (-110)
07-28 11:11:47.208 0 0 E : [ T487] ieee80211 phy0: brcmf_cfg80211_scan: scan error (-110)
07-28 11:11:47.214 487 487 E wificond: NL80211_CMD_TRIGGER_SCAN failed: Connection timed out
07-28 11:11:47.204 580 2249 I chatty : uid=1000(system) BackgroundDexOp identical 20 lines
07-28 11:11:47.207 580 2249 I system_server: The ClassLoaderContext is a special shared library.
07-28 11:11:47.214 463 477 V installd: DexInv: --- BEGIN '/apex/com.android.wifi/javalib/service-wifi.jar' ---
07-28 11:11:47.214 580 735 E WificondScannerImpl: Failed to start scan, freqs=null
07-28 11:11:47.242 2250 2250 I dex2oat32: /apex/com.android.art/bin/dex2oat32 --input-vdex-fd=-1 --output-vdex-fd=9 --updatable-bcp-packages-file=/system/etc/updatable-bcp-packages.txt --resolve-startup-const-strings=true --max-image-block-size=524288 --compiler-filter=verify --classpath-dir=/apex/com.android.wifi/javalib --class-loader-context=PCL[];PCL[/system/framework/com.android.location.provider.jar:/system/framework/services.jar:/system/framework/ethernet-service.jar:/apex/com.android.permission/javalib/service-permission.jar:/apex/com.android.ipsec/javalib/android.net.ipsec.ike.jar] --generate-mini-debug-info --compact-dex-level=none --compilation-reason=boot
07-28 11:11:47.246 2250 2250 I dex2oat32: setting boot class path to /apex/com.android.art/javalib/core-oj.jar:/apex/com.android.art/javalib/core-libart.jar:/apex/com.android.art/javalib/core-icu4j.jar:/apex/com.android.art/javalib/okhttp.jar:/apex/com.android.art/javalib/bouncycastle.jar:/apex/com.android.art/javalib/apache-xml.jar:/system/framework/framework.jar:/system/framework/ext.jar:/system/framework/telephony-common.jar:/system/framework/voip-common.jar:/system/framework/ims-common.jar:/system/framework/framework-atb-backward-compatibility.jar
07-28 11:11:47.282 2203 2225 E AdapterState: BLE_TURNING_ON : BLE_START_TIMEOUT
07-28 11:11:47.282 2203 2225 I AdapterState: BLE_TURNING_OFF : entered
07-28 11:11:47.282 2203 2225 D AdapterProperties: Setting state to BLE_TURNING_OFF
07-28 11:11:47.283 2203 2225 D BluetoothAdapterService: updateAdapterState() - Broadcasting state BLE_TURNING_OFF to 1 receivers.
07-28 11:11:47.283 580 616 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: BLE_TURNING_ON > BLE_TURNING_OFF
07-28 11:11:47.283 580 616 D BluetoothManagerService: Sending BLE State Change: BLE_TURNING_ON > BLE_TURNING_OFF
07-28 11:11:47.283 2203 2225 D AdapterProperties: onBleDisable
07-28 11:11:47.285 2203 2203 D BtGatt.DebugUtils: handleDebugAction() action=null
07-28 11:11:47.289 2203 2203 W droid.bluetoot: [0728/111147.288944:WARNING:bta_gattc_api.cc(61)] GATTC Module not enabled/already disabled
07-28 11:11:47.289 2203 2203 W droid.bluetoot: [0728/111147.289127:WARNING:bta_gatts_api.cc(56)] GATTS Module not enabled/already disabled
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: exception when invoking removeOnUidImportanceListener
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: java.lang.IllegalArgumentException: Listener not registered: com.android.bluetooth.gatt.ScanManager$2@bc6c4ea
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: at android.app.ActivityManager.removeOnUidImportanceListener(ActivityManager.java:3863)
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: at com.android.bluetooth.gatt.ScanManager.cleanup(ScanManager.java:157)
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: at com.android.bluetooth.gatt.GattService.cleanup(GattService.java:266)
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: at com.android.bluetooth.btservice.ProfileService.onDestroy(ProfileService.java:211)
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: at android.app.ActivityThread.handleStopService(ActivityThread.java:4349)
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: at android.app.ActivityThread.access$1900(ActivityThread.java:237)
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1956)
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: at android.os.Handler.dispatchMessage(Handler.java:106)
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: at android.os.Looper.loop(Looper.java:223)
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: at android.app.ActivityThread.main(ActivityThread.java:7660)
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: at java.lang.reflect.Method.invoke(Native Method)
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:592)
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:947)
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: exception when invoking unregisterReceiver(mLocationReceiver)
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: java.lang.IllegalArgumentException: Receiver not registered: com.android.bluetooth.gatt.ScanManager$3@a9d53db
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: at android.app.LoadedApk.forgetReceiverDispatcher(LoadedApk.java:1459)
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: at android.app.ContextImpl.unregisterReceiver(ContextImpl.java:1642)
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: at android.content.ContextWrapper.unregisterReceiver(ContextWrapper.java:715)
07-28 11:11:47.290 2203 2203 W BtGatt.ScanManager: at com.android.bluetooth.gatt.ScanManager.cleanup(ScanManager.java:178)
07-28 11:11:47.324 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/android/net/ip/IpClientCallbacks;.onIpClientCreated is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.324 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/android/net/ip/IpClientCallbacks;.onNewDhcpResults is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.324 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/android/net/ip/IpClientCallbacks;.onPostDhcpAction is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.324 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/android/net/ip/IpClientCallbacks;.onPreDhcpAction is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.324 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/android/net/ip/IpClientCallbacks;.onProvisioningFailure is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.325 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/android/net/ip/IpClientCallbacks;.onProvisioningSuccess is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.325 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/FieldInfo;.getCachedSizeField is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.325 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/FieldInfo;.getEnumVerifier is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.325 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/FieldInfo;.getField is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.325 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/FieldInfo;.getFieldNumber is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.325 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/FieldInfo;.getMapDefaultEntry is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.325 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/FieldInfo;.getMessageFieldClass is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.325 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/FieldInfo;.getOneof is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.325 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/FieldInfo;.getPresenceField is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.325 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/FieldInfo;.getPresenceMask is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.325 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/FieldInfo;.getType is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.325 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/FieldInfo;.isEnforceUtf8 is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.325 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/FieldInfo;.isRequired is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.325 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/OneofInfo;.getCaseField is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.325 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/OneofInfo;.getValueField is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.326 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/nano/FieldArray;.dataAt is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.326 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/nano/FieldArray;.size is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.326 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/nano/FieldData;.computeSerializedSize is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.326 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/com/google/protobuf/nano/FieldData;.writeTo is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.326 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/org/ksoap2/SoapEnvelope;.parseBody is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.326 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/org/ksoap2/SoapEnvelope;.writeBody is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.328 2250 2250 W dex2oat32: Method Lcom/android/wifi/x/org/ksoap2/transport/HttpTransportSE;.getServiceConnection is abstract, but the declaring class is neither abstract nor an interface in dex file service-wifi.jar
07-28 11:11:47.758 826 2004 I PermissionControllerServiceImpl: Updating user sensitive for user 0
07-28 11:11:47.761 826 858 I UserPackageInfos: updating UserPackageInfosLiveData for user 0
07-28 11:11:47.770 826 860 I LancherPackagesLiveData: updating LauncherPackageLiveData
07-28 11:11:48.284 2203 2225 E AdapterState: BLE_TURNING_OFF : BLE_STOP_TIMEOUT
07-28 11:11:48.284 2203 2225 I AdapterState: OFF : entered
07-28 11:11:48.284 2203 2225 D AdapterProperties: Setting state to OFF
07-28 11:11:48.285 2203 2225 D BluetoothAdapterService: updateAdapterState() - Broadcasting state OFF to 1 receivers.
07-28 11:11:48.286 580 616 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: BLE_TURNING_OFF > OFF
07-28 11:11:48.286 580 616 D BluetoothManagerService: Bluetooth is complete send Service Down
07-28 11:11:48.286 580 616 D BluetoothManagerService: Broadcasting onBluetoothServiceDown() to 5 receivers.
07-28 11:11:48.286 1078 1097 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@e0746ba
07-28 11:11:48.286 580 616 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@7923992
07-28 11:11:48.286 1136 2142 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@4bb240c
07-28 11:11:48.286 580 616 D BluetoothManagerService: unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@7923992 mBinding = false mUnbinding = false
07-28 11:11:48.287 2203 2222 D BluetoothAdapter: onBluetoothServiceDown: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@1540f06
07-28 11:11:48.287 797 818 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@829b590
07-28 11:11:48.294 2203 2203 D BluetoothAdapterService: onUnbind() - calling cleanup
07-28 11:11:48.294 2203 2203 D BluetoothAdapterService: cleanup()
07-28 11:11:48.294 580 616 D BluetoothManagerService: Sending BLE State Change: BLE_TURNING_OFF > OFF
07-28 11:11:48.297 580 616 D BluetoothManagerService: Entering STATE_OFF but mEnabled is true; restarting.
07-28 11:11:48.297 580 616 E BluetoothManagerService: waitForState [10] time out
07-28 11:11:48.301 2203 2203 W BluetoothSdpJni: Cleaning up Bluetooth SDP Interface...
07-28 11:11:48.301 2203 2203 W BluetoothSdpJni: Cleaning up Bluetooth SDP object
07-28 11:11:48.302 2203 2203 D BluetoothKeystoreService: cleanup
07-28 11:11:48.302 2203 2203 D BluetoothKeystoreService: setBluetoothKeystoreService(): set to: null
07-28 11:11:48.302 2203 2203 D BluetoothAdapterService: cleanup() - Cleaning up adapter native
07-28 11:11:48.625 2250 2250 I dex2oat32: dex2oat took 1.386s (4.344s cpu) (threads: 4) arena alloc=0B (0B) java alloc=742KB (759840B) native alloc=2564KB (2626256B) free=4747KB (4861760B)
07-28 11:11:48.638 463 477 V installd: DexInv: --- END '/apex/com.android.wifi/javalib/service-wifi.jar' (success) ---
07-28 11:11:48.642 463 477 V installd: DexInv: --- BEGIN '/apex/com.android.os.statsd/javalib/service-statsd.jar' ---
07-28 11:11:48.673 2256 2256 I dex2oat32: /apex/com.android.art/bin/dex2oat32 --input-vdex-fd=-1 --output-vdex-fd=9 --updatable-bcp-packages-file=/system/etc/updatable-bcp-packages.txt --resolve-startup-const-strings=true --max-image-block-size=524288 --compiler-filter=verify --classpath-dir=/apex/com.android.os.statsd/javalib --class-loader-context=PCL[];PCL[/system/framework/com.android.location.provider.jar:/system/framework/services.jar:/system/framework/ethernet-service.jar:/apex/com.android.permission/javalib/service-permission.jar:/apex/com.android.ipsec/javalib/android.net.ipsec.ike.jar] --generate-mini-debug-info --compact-dex-level=none --compilation-reason=boot
07-28 11:11:48.677 2256 2256 I dex2oat32: setting boot class path to /apex/com.android.art/javalib/core-oj.jar:/apex/com.android.art/javalib/core-libart.jar:/apex/com.android.art/javalib/core-icu4j.jar:/apex/com.android.art/javalib/okhttp.jar:/apex/com.android.art/javalib/bouncycastle.jar:/apex/com.android.art/javalib/apache-xml.jar:/system/framework/framework.jar:/system/framework/ext.jar:/system/framework/telephony-common.jar:/system/framework/voip-common.jar:/system/framework/ims-common.jar:/system/framework/framework-atb-backward-compatibility.jar
07-28 11:11:48.680 2256 2256 W dex2oat32: Could not reserve sentinel fault page
