Hi All,
I'm using imx6q on Android 7 platform. To stream data from camera i need gstreamer. So how to add Gstreamer support on this Android BSP.?
Aravinth
I got information from codec team:
"I haven't heard of an effort like this, but freescale codecs for openMAx are on android if that helps."
how to invoke the openMAX service to open the camera stream data on Android sys?
I have RAW Bayer sensor camera How can use above method to capture in Android.?
Aravinth
imx6q can supports raw data capture, but you need to convert it to yuv or RGB, it's about capture, not about codec. then you can use the openmax extended codec package
How to convert into yuv or RGB. Do you have any reference code.?
Aravinth
unfortunately we don't offer this source code for customer
