How to solve timing margin issues from fabrication side in custom hardware design ?
1,126件の閲覧回数
peteramond
Contributor V
Hi All,
This is regarding i.MAX6Q based custom hardware design and I'm having timing margin issues in I/O interface between chipset and dram. If I/O interface margin is poor by routing issue or layout, it may cause failure depending on noise pattern ( different application make different noise  level). So to solve this issue what do you suggest ?
1) Can we do this using chipset design option to control this kind of timing like phase shift  for tDQS and tDQ.? Can you explain how to do this ?
2) Is it possible to down operating frequency ( ex 2400Mbps --> 2133Mbps ) How can we do this in uboot level ?
3) If it is related to clock timing, We can add capacitance or change termination resistance on CLK and CLK/. To do this what we should do ? Which parameter should I change in DDR initialization script before do memory calibration ?
Peter.
ラベル(4)
3 返答(返信)
921件の閲覧回数
igorpadykov
Hi Peter
1.3. please look on AN4467 i.MX 6 Series DDR Calibration
https://www.nxp.com/docs/en/application-note/AN4467.pdf
2. for changing frequency examples one can look at linux cpufreq, bus drivers described in
Chapter 23 CPU Frequency Scaling (CPUFREQ) Driver, Chapter 24 Dynamic Bus Frequency Driver
attached Linux Manual. For boot with lower frequencies one can use BT_FREQ=1 option
described in Table 8-4. Normal frequency clocks configuration  i.MX6DQ Reference Manual
https://www.nxp.com/docs/en/reference-manual/IMX6DQRM.pdf
921件の閲覧回数
peteramond
Contributor V
Hi igorpadykov
How can I change BT_FREQ=1 value ? Is that in U-boot DCD configuration files ? Could you please tell me the method ?
Peter.
921件の閲覧回数
igorpadykov
Hi Peter
please look at BT_FREQ (BOOT_CFG3[2]) description in
Table 8-2. Boot eFUSE descriptions, Table 8-3. GPIO override contact assignments
i.MX6DQ Reference Manual.
