How to solve reports "failed to set baudclk rate" error in imx6dl android6.0 platform?
674件の閲覧回数
imx-talent
Hi, everybody!
            I config dts ssi2 as i2s master below:
ssi2:{
clocks = <&clks IMX6QDL_CLK_SSI2_IPG>,
<&clks IMX6QDL_CLK_SSI2>;
clock-names = "baud";
         it reports "failed to set baudclk rate\n" in the function  fsl_ssi_set_bclk(), how to solve the error and config i2s master in imx6dl android6.0 platform?
        Thank you and good luck to you!
タグ(1)
2 返答(返信)
521件の閲覧回数
igorpadykov
Hi talent
please check ssi master usage on
http://permalink.gmane.org/gmane.linux.alsa.devel/127795
521件の閲覧回数
imx-talent
I check ssi master is correct.but how to configure bitclock output 2.8Mhz?
