Hi, everybody!
I config dts ssi2 as i2s master below:
ssi2:{
clocks = <&clks IMX6QDL_CLK_SSI2_IPG>,
<&clks IMX6QDL_CLK_SSI2>;
clock-names = "baud";
it reports "failed to set baudclk rate\n" in the function fsl_ssi_set_bclk(), how to solve the error and config i2s master in imx6dl android6.0 platform?
Thank you and good luck to you!
Hi talent
please check ssi master usage on
http://permalink.gmane.org/gmane.linux.alsa.devel/127795
