How to shift the PWM phase?
kenji
Hi Team
How can I shift the FlexPWM phase like below figure?
Tags (2)
FelipeGarcia
Hi Kenji,
I recommend you to check mc_pmsm example that implements phase shift in three different flexpwm signals. The image you are referring is the counter representation of the PWM signal not the signal itself.
Felipe
- We are following threads for 7 weeks after the last post, later replies are ignored. Please open a new thread and refer to the closed one, if you have a related question at a later point in time.
