How to set IR-receiver GPIO
1,182 次查看
bbq56go
Hi~!
Device is  i.MX 8M mini evk
yocto version is imx-4.14.78-1.0.0_ga
I have been trying ir-receiver solution.
 1. I tried to modify the dts file as below
.../tmp/work-shared/imx8mmevk/kernel-source/arch/arm64/boot/dts/freescale/fsl-imx8mm-evk.dts
      &iomux {
         pinctrl-names = "default";
2. Kernel Compile..
   $ bitbake -c devshell virtual/kernel
      make Image
      make modules
      make dtbs
   $ bitbake -C compile virtual/kernel
3. And Copy&Paste new dtb file in My SD-card
4. but, It doesn't apply.
Unfortunately, I'm not familiar with embedded Linux.
Please suggest me how can I supposed to add GPIO.
标记 (4)
959 次查看
igorpadykov
Hi JaeHo
one can check yocto tutorials
i.MX Yocto Project: How can I (quickly) modify the kernel and test it?
Getting started with Yocto on Wandboard - Wandboard Wiki
960 次查看
igorpadykov
Hi JaeHo
