Hi All,
When we tried to update the initial boot loader(u-boot) on IMX6 sabrelite quad core platform, some how SPI-NOR flash completely erased and not yet recovered.
We have followed some of the links which is mentioned below to recovery the SPI-NOR boot loader, but we haven't succeeded and we struck at this step. And in this case on serial window nothing has displayed once power up the IMX6 board.
i.MX6x SABRE Lite SPI Flash Recovery - Linux on ARM - eewiki
http://boundarydevices.com/unbricking-nitrogen6x-sabre-lite-i-mx6-board/
Can any one help on this, how to get back the board into normal mode working mode.
Your suggestions are very helpful for us.
Thanks all in advance.
Thanks & Regards
Ch.Siva
Hi, Eric!
The same problem.
The original boot loader was on the SPI-NOR has been cleared.
USB otg port is broken so it is not available.
Anything can boot only to SD card.
Thanks and Best Regards ,
James
Hi James,
When you say "otg port is broken", do you mean physically broken?
If so, you can contact our office (info@boundarydevices.com) and see about getting it repaired.
Hi Eric,
Has produced the current SabreLite circuit board as the base.
I need help.
SabreLite board and elsewhere are as follows:
Item SabreLite Coustom
UART UART2 -> UART1
SD3 SD -> T-flash
SD4 T-flash -> Disable
NAND Disable -> 1GB (MT29F8G08ABACA)
DDR3 1GB -> 2GB (MT41K256M16HA)
RGB port LCD -> GPIO
Where do I need to modify the U-boot?
Do I need to modify the part anywhere below?
board / boundary / nitrogen6x.c and include / configs / nitrogen6x.h
Linux is frustrating because the first time.
*U-boot received from the Boundary site.
*Succeeded to compile and download the SabreLite Board.
Please check the reply.
As Eric said, depending on your deadlines and wishes it may be a challenging task.
jamesko, you will also need trackability, an easy to use development environment and several other small aspects which together will turn your idea into a great product.
Hi James,
Linux is probably the easiest part of your job. You're going to need a custom U-Boot along with a custom Linux kernel.
We're not in the strictly software business, so we can't assist with this. You may want to reach out to others on the list for help.
This is not a job for the inexperienced unless you have quite a bit of time for learning each of the parts.
Ouch! This looks horribly burned.
It's also not one of ours...
Hi Everyone,
Is anyone able to reflash original bootloader to SPI-NOR flash.
We followed the steps mentioned in https://wiki.linaro.org/Boards/MX6QSabreLite : for boot from SD.
but after that it erased original bootloader from Flash. No prints comes on serial console.
We tried Mfg Tools with "MX6Q-Sabreauto-SPI_NOR & SD card" profile but still no luck. It is not giving any prints
on serial. Is it possible to put u-boot on SD card and boot from that or it mandatory to put original bootloader to
SPI NOR flash to getting it functional.
Please help me to resolve this.
Hi.
I am in same problem with you.
Did you solve it???
If YES, Could you give me some advice??
Regards.
You should use either imx_usb (under Linux) or SB_LOADER.exe under Windows as described in these two posts:
Hey! Thank you for advice!
I am stuck with after that command.
loading binary file(../u-boot.mx6qsabrelite) to 177ff400, skip=0, fsize=5bc00 type=aa
<<<375808, 375808 bytes>>>
jumping to 0x177ff400
Than.
Nothing happend! Do I have to change the mode of swich? or Do I have use command screen???
Or any other way?
I already failed to using way that based windows.
Any tiny hint will be great ! Thanks !
Hello dayoung,
The "jumping to..." message says that the binary was downloaded and should be running.
If you're connected with a terminal emulator to the console port, you should see output from U-Boot.
Hello Eirc!
Your Advice is very helpfu!
Thank you very much!
Hello community ,
i have the same problem that no output from console of u-boot or linux
but i have SD corrupted , so i tried i.MX6x SABRE Lite SPI Flash Recovery - Linux on ARM - eewiki to delete and repartition SD card , copy files but still no output comes out
My question is : what are the files really needed to be on SD card to just be able to replace corrupted U-boot (i think ) with U-Boot binary from SD card ?? and how this process happens if SPI-NOR itself has been trashed (as i think too) ??
mentioned link just copy one file to SD card , Boundary devices adds boot/upgrade script files .Linaro link here copied one file usdhc3/4.bin to SD card to be flashed into the SPI NOR in assumption SD has valid U-boot binary/Linux image ??
how do files differ with each situation/problem ?!
my situation is :
-no output from console cable at able (U-boot)
-can not use MFGTool (USB cable is not detected at all)
-can not use JTAG image download (for any U-boot /application demos) : connection reset by peer
-SD corrupted : tried to format,repartition, copy file to it , still no output at all
i really got confused and stucked with no progress ..
any help is really appreciated ..
SD: to reflash a SD, in a linux console type the following command
'dd if=good-u-boot.bin of=/dev/sdX seek=2 skip=2 && sync
SPI-NOR: Try latest manufacturing tool and set choose the SPI-NOR profile
Hello Leonardo ,
thank you
i tried many times to copy files to SD card but the problem is that U-boot does not get running to be able to copy good-u-boot.bin to SPI-NOR ..
for MFGTool , i can not use it as USB cable is not detected by MFGTool.exe ..
the same cable problem prevents me from using Boundary devices USB_loader utility .
Hi Leonardo,
This sounds like a hardware problem of some sort. Our experience is that the RBL just works...
Nehal and I had some back-and-forth on our blog and it sounds like this board is messed up somehow.
