Hi ,
How to modify *.inc script to *.cfg after DDR stress testing ? I want to use file *.inc for u-boot ddr config.
Thanks a lot.
it would be better to "convert" .inc initialization script to DCD table of U-boot manually,
since it depends on U-boot version.
Yuri
Thank you very much.
And how to convert to DCD table?
Thanks a lot.
.inc file has format as following :
setmem /32 0x021b0800 = 0xa1390003
meaning write data 0xa1390003 to address 0x021b0800.
corresponding line of the DCD is as following :
DATA 4, 0x021b0800, 0xa1390003
Yuri.
OK, thanks a lot.
Is there a script to convert ?
Or should I must convert it manual?
I think - manually.
~Yuri.
OK.
Thanks a lot.
