How to disable flexcan on M4 for imx6sx
1,003 次查看
jingyangxie
Contributor V
Hi,all
     I have a imx6sx-sdb board,I want a9 can use flexcan1,when I build imx6sx-sdb-m4.dtb(flexcan1 is enabled in imx6sx-sdb-m4.dts),and run any m4image(for example,hello_world_imx6sx_sdb_m4.bin),the flexcan on a9 disabled,can anyone knows how to disable flexcan on M4 ,and enable flexcan on a9 when m4image runs?
标签 (2)
821 次查看
igorpadykov
Hi jingyang
in dts file one can set for flexcan status = "okay"  and
if using FreeRTOS BSP, check m4 exclusive permissions for that module
defined in hardware_init.c: hardware_init(), RDC_SetPdapAccess().
821 次查看
jingyangxie
Contributor V
Hi,igor
    thanks for your answer! the problem has been solved
821 次查看
frl
Dear Jingyang xie
- I have the exact same issue that puzzles me a bit.
The FreeRTOS Hello_world example does not in any way grasp the flexcan module so I would assume that it should not be nescessarry to do anything extra to allow the A9 access to the module - so what did You do to solve the issue?
Did You explicitly have to force the M4 NOT to use the flexcan - seems a bit backwards to me!?
Best regards Frank
