How to define variables to SRAM or SDRAM with certain modifications?
792 次查看
vwsncr
    Now , i'm using the imxrt1052 with SDRAM. All variables are in the SDRAM. But i want some variables in SRAM, and others in SDRAM. How to do ?
    Thanks.
734 次查看
jingpan
Hi @vwsncr ,
First of all, please read RT1052 reference manual, chapter 3 is about it. RT1052 has internal RAM include ITCM, DTCM and OCRAM. Most of the examples in SDK use internal RAM. To define variables to internal SRAM or SDRAM, you must define like this
#define AT_NONCACHEABLE_SECTION_INIT(var) __attribute__((section("NonCacheable.init"))) var
Please see fsl_common_arm.h for detail.
Sometimes you also have to modify the link file. To change memory map, it's in MCUXpresso IDE ->right click project name ->properites->MCU settings. To change link file, it's in MCUXpresso IDE ->right click project name ->properites->Settings->Managed linker script.
Jing
4 回复数
771 次查看
jingpan
Hi @vwsncr ,
RT1052 SEMC support SRAM and SDRAM simultaneously. Their /CS is standalone. And their control registers are different.
Jing
756 次查看
vwsncr
Thanks for reply ,
    Sorry for my poor english. The SRAM that i want to say is the MCU's SRAM not external SRAM , and the SDRAM is external SRAM. Now both are on my board ,  but i only can used the external SRAM. I don't know how to used the MCU's SRAM.  In "MCU settings" page and datasheet, i can see the RAM named "SRAM_DTC","SRAM_ITC","SRAM_OC".
735 次查看
jingpan
Hi @vwsncr ,
Jing
728 次查看
vwsncr
have worked
