i'm trying to burn my rootfs image to partition 2. but i needed to have a temporary copy to another partition before i can do the `dd` data duplicate to the partition 2. is there a way that i can directly burn this to the partition 2 without copying it temporarily?
I'm using UUU for this.
this is the part where i burn it in my current .lst file.
# burn rootfs to partition 2
FBK: ucmd mmc=`cat /tmp/mmcdev`; while [ ! -e /dev/mmcblk${mmc}p5 ]; do sleep 1; done
FBK: ucmd mmc=`cat /tmp/mmcdev`; mkfs.ext4 -F -E nodiscard /dev/mmcblk${mmc}p5
FBK: ucmd mkdir -p /mnt/ext4p5
FBK: ucmd mmc=`cat /tmp/mmcdev`; mount -t ext4 /dev/mmcblk${mmc}p5 /mnt/ext4p5
FBK: ucp OSFiles/image-imx8mn.ext4.verity.signed t:/mnt/ext4p5
#FBK: sync
FBK: ucmd mmc=`cat /tmp/mmcdev`; dd if=/mnt/ext4p5/image-imx8mn.ext4.verity.signed of=/dev/mmcblk${mmc}p2 bs=1k conv=fsync
#FBK: sync
FBK: ucmd umount /mnt/ext4p5
Thank you!
