How to create an LTIB package
AdCmo
All,
Are there any better instructions on how to create an LTIB package?
I tried following "helloworld" package and these instructions:
http://www.bitshrine.org/autodocs/LtibFaq.html#ref_89
But I am still having issues with the package not building.
I have a package with contents like this:
pck_dir
   +--fileA.c
   +--fileA.h
   +---tests
           +---- file1.c
           +----file2.c
    +--hdrs
           +----fileX.h
           +----fileZ.h
I have attached my spec file and my makefile.
They don't seem to work, I get the error below.
Please let me know if you have done this successfully before.
I had given up on LTIB and using the ordinary make files, but I would like
to get my package working with LTIB.
-----------------------------------------------BEGIN DUMP--------------------------
:~/mxc/ltib$ ./ltib -m scbuild -p pck_dir.spec
Processing: pck_dir
Build path taken because: directory build, build key set, no prebuilt rpm,
rpmbuild --dbpath /home/mxc/ltib/rootfs//var/lib/rpm --target arm --define '_unpackaged_files_terminate_build 0' --define '_target_cpu arm' --define '__strip strip' --define '_topdir /home/mxc/ltib/rpm' --define '_prefix /usr' --define '_tmppath /home/mxc/ltib/tmp' --define '_rpmdir /home/mxc/ltib/rpm/RPMS' --define '_mandir /usr/share/man' --define '_sysconfdir /etc' --define '_localstatedir /var' -bc --short-circuit /home/mxc/ltib/dist/lfs-5.1/pck_dir/pck_dir.spec
Building target platforms: arm
Building for target arm
Executing(%build): /bin/sh -e /home/mxc/ltib/tmp/rpm-tmp.30662
+ umask 022
+ cd /home/mxc/ltib/rpm/BUILD
+ cd pck_dir-1.0
+ make prefix=/usr
Makefile:36: *** missing separator. Stop.
error: Bad exit status from /home/mxc/ltib/tmp/rpm-tmp.30662 (%build)
RPM build errors:
Build time for pck_dir: 0 seconds
Failed building pck_dir
f_scbuild() returned an error, exiting
traceback:
main:560
Exiting on error or interrupt
-----------------------------------------------END DUMP--------------------------
Ad.
Original Attachment has been moved to: 291-pkc_dir.spec
