How to change splash screen bmp file on i.MX23?
YaseminYILMAZ1z
Hi all,
I want to change splash screen bmp file that is shown during startup on i.MX23 Windows Embedded Ce 6.0 based device. Is there anyone trying this? Is the modification of bootloader required?
Thanks a lot for your helps,
Yasemin
G_rio
Hello Yasemin,
You need to do these steps.
1 - create a dir in c:\WINCE600 (like Personalization)
2 - put your splash file (Splash.jpg or bmp) in Personalization folder
3 - create a new empty subproject and add these commands
   xxxxx.bib
       FILES
       splash.jpg       $(_WINCEROOT)\Personalization\splash.jpg                   NK H
   xxxxx.reg
       ; initial value for background bitmap
       [HKEY_CURRENT_USER\ControlPanel\Desktop]
       "wallpaper"="\\Windows\\Splash.jpg"
Use your own method to rebuild or (clean and rebuild all)
daiane_angolini
