RE: Eclipse 2021, imx8qxp si b0, ubuntu 20.04, and NXP IMX8 yocto BSP L5.10.35
i have done successfully to install yocto SDK plugin to Eclipse , test OK. but
i want to use Eclipse Project to build DEMO Framework . use yocto cmake or yocto autotools . please tell me how to do it . thanks
1
first i can use yocto autotools hello world project. TEST OK
2
but cannot use a empty yocto autotools project , dun know why?
3
i try to open a yocto cmake hello world project, even worsen , it is failed to build always shows cannot found CMAKE, but i use " cmake --version " show 3.19.5 .
it is seems that yocto plug in for eclipse not working with NXP IMX8 BSP?
4
if ok then next : how to build the imx gpu(not npu , sori typo) demo framework ?
please help me
We don't have such guide for eclipse.If you want to use NPU demo ,please follow this guide:https://www.nxp.com/docs/en/user-guide/IMX-MACHINE-LEARNING-UG.pdf
sorry my fault: i mean gpu but typo a "npu". sorry abt tht.
we can build it by using yours Fslbuild.py , command line /scripts way. BUT,
i mean tht many people need to use IDE to build the gtec-demo-framework: if you do a Project/Plug in for eclipse then better .then easier to build it and see the results thanks
Yocto SDK plug in for Eclipse ? and build NXPmicro gtec-demo-framework in Eclipse ?? how to do ???
