How to access OTP in MFTTools?
LiuHui
I compared the source code with some other version which is for STMP3780 and can support OTP access, I find that the OPT related codes are removed.
Is there any version can support OTP access for IMX28?
If there is not, can I add it manually?
Best Regards
LiuHui
Hi Marc,
It seems that my updater does not support OtpSendData command. Is there any package I shuold install?
Thanks.
Best Regards
Liuhui
Marc coussement said:
I have the same question, a easy way to program MAC address into OTP with Mfgtool.
Kind Regards
Marc
 Liu Hui said:
Thanks.
My situation is,  I want to write some unique values to the HW_OCOTP_CUSTx for every device during manufacturing.
The tools you provoded  can not meet my requirement.
So I am still trying to find the possibility to add the OTP support to Mfgtools before you confirm me.
Is there any other suggestions?
Best Regards.
MarcCoussement
Kind Regards
Marc
 Liu Hui said:
Thanks.
Best Regards.
LiuHui
Thanks.
Best Regards.
Yuri
