How maximum FPC cable distance should I use for MIPI DSI LCD ?
1,795 次查看
talel_hajsalem
I'm working on a custom IMX8MM board, and I have an LCD display.
when using a 5cm FPC cable and its working, but when using 10cm or 20cm it does not work.
If I decrement the pixel clock it sometimes work.
How maximum length should I don't pass?
Talel
1,788 次查看
igorpadykov
Hi Talel
cable length depends on many factors, including cable material, signal losses in board/cable and
connectors, impedance matching, so I am afraid there is no simple formula to calculate.
One can try to find it experimentally controlling signal quality by oscilloscope or try to perform ibis modelling.
1,789 次查看
igorpadykov
Hi Talel
