How maximum FPC cable distance should I use for MIPI DSI LCD ?
1,795件の閲覧回数
talel_hajsalem
I'm working on a custom IMX8MM board, and I have an LCD display.
when using a 5cm FPC cable and its working, but when using 10cm or 20cm it does not work.
If I decrement the pixel clock it sometimes work.
How maximum length should I don't pass?
Talel
1,788件の閲覧回数
igorpadykov
Hi Talel
cable length depends on many factors, including cable material, signal losses in board/cable and
connectors, impedance matching, so I am afraid there is no simple formula to calculate.
One can try to find it experimentally controlling signal quality by oscilloscope or try to perform ibis modelling.
1,789件の閲覧回数
igorpadykov
Hi Talel
