We issue a question in "BT656" every 8 seconds, the screen will stop 0.1~0.2s times.
We found that some issues may be de-interlaced on IMX.6DL, how can we close below "-adaptive-dei-motion-mode" fuction on QNX.
"-adaptive-dei-motion-mode=admodeA string that specifies the motion mode for the adaptive de-interlacer. The mode can be one of the following values, which are case-sensitive:
Current Hardware:
Video IC( LSI ML86V8201)
SOC(iMX.6DL)
Camera to Video IC( BT656) to SOC
SOC(RGB888)to Video IC(RGB666) to Panel
thank you
I can not see the video you attached. Here I found the https://community.nxp.com/docs/DOC-94019 hope this can do help for you.
The QNX software is not supported by nxp, suggest to apply to QNX tech support directly. You can refer to https://boundarydevices.com/qnx-sdp-7-0-imx-platforms/
Hope this can do help for you
Have a nice day
Rita
