I find many engines ask about the support of OTG HNP with imx6 yotco 3.10.17 .And now I also meet this question .I trying to perform dynamic role switch from host to device with USB OTG HNP. And first I use libusb libusb_control_transfer() function ,send role switch request to B-devcie .And B-device response the request and disconnect itself from the bus .According to the usb otg document said :Next the A-device should turn on the D+ pull up.And so dispirited,i don't konw how to turn on the D+ pull up.
Does anyone know :
1 ,Can i use linux standard drives to perform role switch ? And how use it ?
2. How can i turn on D+ pull up ?
Thanks .
已解决! 转到解答。
Chunfan,
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
Chunfan
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
Yixng
