How can I do dual-role switch with iMX6?
2,559件の閲覧回数
jichunfan
    I find many engines ask about the support of OTG HNP with imx6 yotco 3.10.17 .And now I also meet this question .I trying to perform dynamic role switch from host to device with USB OTG HNP. And first I use libusb  libusb_control_transfer() function ,send role switch request  to B-devcie .And B-device response the request and disconnect itself from the bus .According to the usb otg document said :Next the A-device should turn on the D+ pull up.And  so dispirited,i don't konw how to turn on the D+ pull up.
Does anyone  know :
1 ,Can i use linux standard drives to perform role switch ? And how use it ?
2. How can i turn on D+ pull up ?
Thanks .
ラベル(4)
1,726件の閲覧回数
CommunityBot
Community Manager
This an automatic process.
We are marking this post as solved, due to the either low activity or any reply marked as correct.
If you have additional questions, please create a new post and reference to this closed post.
NXP Community!
6 返答(返信)
1,727件の閲覧回数
CommunityBot
Community Manager
NXP Community!
1,726件の閲覧回数
YixingKong
Senior Contributor IV
Chunfan,
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
1,726件の閲覧回数
YixingKong
Chunfan
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
Yixng
1,726件の閲覧回数
JackyAtFreescal
Senior Contributor II
The official yotco 3.10.17 release does not support HNP. It will be supported in future release.
Jacky
1,726件の閲覧回数
YixingKong
JackyAtFreescale, could you look into the questions please?
Yixing
1,726件の閲覧回数
JackyAtFreescal
Yes, I'm working on it.
