How can I create a patch for .config in my custom layer
130 次查看
Derek0902
After I modified kernel config use this command below, there is a .config in <build_dir>/tmp/work/imx8mqevk-poky-linux/linux-imx/6.1.36+gitAUTOINC+04b05c5527-r0/build
$ bitbake linux-imx -c menuconfig
Then I override defconfig with .config and create a patch in my custom layer. But it didn't take effect in my board.
$ cp .config <build_dir>/tmp/work/imx8mqevk-poky-linux/linux-imx/6.1.36+gitAUTOINC+04b05c5527-r0/git/arch/arm64/configs/defconfig
I want to create a patch for this config in my custom layer. How can I do that?
Thanks & Regards,
Derek Lin
87 次查看
pengyong_zhang
HI, @Derek0902
Sorry to reply late
1. Make sure you have added the configuration changes in your customization layer. This is usually done by adding a conf/layer.conf file, which is read during the build process.
2. In the top-level directory of your customization layer, run the following command to create the patch file:
bitbake-diff . > custom-layer-config-patch
3. This command compares the current.config file in your build directory with the prebuild pristine.config file and generates a patch file custom-layer-config-patch.
88 次查看
pengyong_zhang
HI, @Derek0902
Sorry to reply late
86 次查看
Derek0902
Hi @pengyong_zhang ,
Thanks for your help. I have found that is in ../source/meta-freescale/recipes-kernel/linux-imx_6.1.bb.
KBUILD_DEFCONFIG:mx6-generic-bsp = "imx_v7_defconfig"
KBUILD_DEFCONFIG:mx7-generic-bsp = "imx_v7_defconfig"
KBUILD_DEFCONFIG:mx8-generic-bsp = "imx_v8_defconfig"
KBUILD_DEFCONFIG:mx9-generic-bsp = "imx_v8_defconfig"
I modified the kernel config successfully.
Thanks & Regards,
Derek Lin
