Hardware ECC Accelerator Layout Select Register
659 次查看
takashitakahash
Hi community.
IMX6DQ RM of sect 17.6.7 Hardware ECC Accelerator Layout Select Register
of  (BCH_LAYOUTSELECT),
Desclibed in Chip Select of CS15 ~ CS0 , as the ball function of iMX6, it is only NAND_CE3 ~ CE0.
What is  CS15 ~ 0 ?
标签 (2)
522 次查看
Yuri
  Only CS0-CS3 bit fields of  BCH_LAYOUTSELECT should be used for i.MX6
Yuri
523 次查看
Yuri
Yuri
