Hab encrpyted image boot for rt1050
919 次查看
jimhuang2
Hi all,
I want to create hab encrypted image boot for the rt1050 evkb, I have some trouble about certificate authority and the dek.
HAB Security Boot
1. CA step issue: The BootRom can verify CA by the public key, Where the public key be stored to provide BootRom?
2. Dek step issue: DEK is generated from random numbers by the Code Signing Tool (CTS). When I upgrade boot image, I have to used dek to generated dek blok and attached to boot image, I'm not sure, can it run?
3. After mass production, We need to maintain private key, public key and dek, is it right?
Best Regard,
Jim
800 次查看
kerryzhou
Hi JingHuan Huang ,
   Sorry for our later reply!
   Before answer your question, I highly recommend you read the AN12079(how to use I.MXRT Security Boot) at first, then it will make you more clear.
   https://www.nxp.com/webapp/sps/download/mod_download.jsp?colCode=AN12079&appType=moderated
   Now, answer your questions:
 Answer: Public key is stored in the RT eFUSE SRK area.
Answer: Dek.bin is the random number, I think you also can use the old dek.bin, but if you want to use the new dek.bin, it's also OK, just do the new operation steps. I suggest you use the new dek when you use the new app code.
Answer: Yes, if you want to program more product, it's better to maintain it.
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
