GPU stress test in imx8qxp
927 次查看
arunsathian
Hi  NXP,
How to stress the GPU in imx8qxp, Can you please guide me. Provide sample code for gpu stress test.
841 次查看
Rita_Wang
Benchmark Tests:
/usr/bin/glmark2-es2-wayland
6 回复数
909 次查看
Rita_Wang
I will confirm it for you, which version BSP are you using?
907 次查看
arunsathian
Hi @Rita_Wang ,
BSP version is imx-5.10.72-2.2.0 .
869 次查看
Rita_Wang
We have the GPU sdk that include several examples for stress the GPU on the Linux BSP, also it includes a benchmark for the testing, you can check the hands on I attach to you. The method is the same.
856 次查看
arunsathian
Hi ,
I found that glmark2 utility is used to stress the gpu, and I just enabled it in the board. glmark2-es2 , glmark-es2-drm , glmark-es2 -wayland , these 3 utilities showing. Among these which should I prefer and can you please provide the commands needed.
842 次查看
Rita_Wang
Benchmark Tests:
779 次查看
arunsathian
Hi @Rita_Wang ,
Thank you!
