GD32A50x 's MFCOM IP is Exactly the same as NXP FlexIO
NXP_MCU_user
I found in GD32A50x_User_Manual_Rev1.1.pdf ,the MFCOM IP is Exactly the same as NXP FlexIO,
for each register and each bit  .
Is there any copyright infringement problem,if i use GD32A50x 's MFCOM IP ?
the related link as follow:
https://www.gd32mcu.com/data/documents/userManual/GD32A50x_User_Manual_Rev1.1.pdf
9. Multi-function communication Interface (MFCOM)
Dhruvit
Hi @NXP_MCU_user,
I hope you are doing well
Please mentioned i.MX processor used in this case.
Thanks & Regards,
Dhruvit Vasavada
Dhruvit
Hi @NXP_MCU_user,
I hope you are doing well.
Waiting for your response.
Thanks & Regards,
Dhruvit Vasavada
