Forward Lifecycle to OEM close from Partial Field Return LC
362 次查看
cchopra
Is there a way to update lifecycle for an IMX8QX to OEM close from Partial Field return LC? I am trying to use sc_seco_forward_lifecycle() but it fails and the seco event seen is SECO Event[0] = 0x0095AF29.
It appears the error is AHAB_ADM_WRONG_LC_IND which means this transition is not supported or LC is wrong? Is it not possible to go back to OEM closed state once its been updated to Partial field return?
标记 (1)
329 次查看
Harvey021
No reverse operation for LC.
Harvey
330 次查看
Harvey021
Harvey
