Hi All,
I am facing issue of Ethernet is not working on imx6ul evk linux. I am using latest Ethernet phy KSZ8081RNB (date code 1613SA3T M001613CWB ). This Ethenet phy is working properly on u-boot level.
One more thing KSZ8081RNB PHY with older date code (1418A2TM13A811M03) is working properly.
Need a help to find out the root cause of this issue.
Dhvanil Patel
Hi Dhvanil
seems first part has silver wire bonding change acording to documents
http://media.digikey.com/pdf/PCNs/Micrel/PPCN140015.pdf
p.2 http://docs-europe.electrocomponents.com/webdocs/13f4/0900766b813f4f61.pdf
so may be suggested to apply to contacts given in these documents for more details.
Hi Igor,
Thank you for your prompt help.
Can you please let us know how should I have to change in linux kernel driver to support it
