I am working on a custom board based on sabre auto board. I am using linux-imx 3.10.17. I have to use ESAI for audio. I am writing a dummy driver which basically registers the soc card (which can then be used in ALSA utilities) and sets the hw params.
Now i have observed that other drivers use following functions in their code
snd_soc_dai_set_tdm_slot() and snd_soc_dai_set_sysclk(). If i am using normal mode(i2s)( not TDM) ,then do i require to use snd_soc_dai_set_tdm_slot() function in my driver?
What is the exact purpose of these functions? What exactly do they do?
I wish to use imx pll4 clock for ESAI. For that, what configuration is needed?
Also I want to set ESAI in master mode. What configuration is needed for that? Do I have to add anything in ESAI block in device tree?
-Thanks
Sharvari Harisangam
Hi Sharvari
snd_soc_dai_set_tdm_slot() and snd_soc_dai_set_sysclk() are
described in kernel alsa documentation:
https://www.kernel.org/doc/htmldocs/alsa-driver-api/ch07.html
https://www.kernel.org/doc/htmldocs/alsa-driver-api/API-snd-soc-dai-set-tdm-slot.html
For linux esai driver configuration one can look at attached Linux Manual
sect.28.4.4 Devicetree Binding, examples from sdk and description of esai test
in Chapter 9 Configuring the ESAI Driver iMX6_Firmware_Guide.pdf
Hello Igor,
I want to use fsl_esai driver for two channels(stereo sound with left and right channel). Should i use network mode or normal mode? also how many slots would be needed in snd_soc_dai_set_tdm_slot() function?
-Thanks
Sharvari
In the function snd_soc_dai_set_sysclk(), how to set the clk_id and dir ? i am confused between ESAI EXTAL clock, ESAI FSYS clock and their directions.when to set which clock and how the direction is determined?
