ERROR: rsdk-1.4.8-r0 do_compile: oe_runmake failed
ERROR: rsdk-1.4.8-r0 do_compile: Execution of '/home/hmecd001523/yocto-bsp/orion-yocto-bsp/build/tmp/work/aarch64-poky-linux/rsdk/1.4.8-r0/temp/run.do_compile.14546' failed with exit code 1:
[Target ... rsdk_linux]
make[1]: warning: jobserver unavailable: using -j1. Add '+' to parent make rule.
make[1]: Entering directory '/home/hmecd001523/yocto-bsp/orion-yocto-bsp/build/tmp/work/aarch64-poky-linux/rsdk/1.4.8-r0/rsdk-1.4.8/os/linux/user'
**** Building CONFIG_CINT ****
CONFIG_SGMII_PHY = 1
CONFIG_CINT = 1
make[2]: Entering directory '/home/hmecd001523/yocto-bsp/orion-yocto-bsp/build/tmp/work/aarch64-poky-linux/rsdk/1.4.8-r0/rsdk-1.4.8/os/osal/linux'
[Compile ... sal_file.c]
/home/hmecd001523/yocto-bsp/orion-yocto-bsp/build/tmp/ext-toolchains/gcc-linaro-aarch64-linux-gnu-4.9-2014.09_linux/bin/../libexec/gcc/aarch64-linux-gnu/4.9.2/cc1: error while loading shared libraries: libz.so.1: cannot open shared object file: No such file or directory
make[2]: *** [/home/hmecd001523/yocto-bsp/orion-yocto-bsp/build/tmp/work/aarch64-poky-linux/rsdk/1.4.8-r0/rsdk-1.4.8/make/Make.depend:4: /home/hmecd001523/yocto-bsp/orion-yocto-bsp/build/tmp/work/aarch64-poky-linux/rsdk/1.4.8-r0/rsdk-1.4.8/build/rsdk_linux/os/osal/linux/./sal_file.o] Error 1
make[2]: Leaving directory '/home/hmecd001523/yocto-bsp/orion-yocto-bsp/build/tmp/work/aarch64-poky-linux/rsdk/1.4.8-r0/rsdk-1.4.8/os/osal/linux'
make[1]: *** [Makefile:50: osal] Error 2
make[1]: Leaving directory '/home/hmecd001523/yocto-bsp/orion-yocto-bsp/build/tmp/work/aarch64-poky-linux/rsdk/1.4.8-r0/rsdk-1.4.8/os/linux/user'
make: *** [Makefile:84: rsdk_linux] Error 2
WARNING: exit code 1 from a shell command.
ERROR: Logfile of failure stored in: /home/hmecd001523/yocto-bsp/orion-yocto-bsp/build/tmp/work/aarch64-poky-linux/rsdk/1.4.8-r0/temp/log.do_compile.14546
Solved! Go to Solution.
how about try the command like
bitbake -c cleansstate rsdk
bitbake rsdk
if still failed, pls give me your detailed build steps and what bsp version and ubuntu version you use
i'm trying to build image on bitbake command but i'm getting errors . please any one give suggestions how to sort out this problem
did you delete and build again? still get the same errors? as I mentioned, share your build commands to double check it, did you install all of ubuntu packages according to the yocto user guide?
bitbake rsdk
bitbake -c cleanall rdk-generic-mediaclient-image
bitbake -c cleansstate rdk-generic-mediaclient-image
i have ran these 2 commands still i am getting the error
ERROR: userland-git-r5 do_compile: oe_runmake failed
