Dual channel on LVDS0 based on Yocto project in i.MX8QM
800件の閲覧回数
Fox-BCJim
Hi Sir,
I have a screen which needs dual LVDS channel as the input sources.
I found that imx8qm-mek-jdi-wuxga-lvds1-panel.dtb was already supported in Yocto.
The LVDS1 could support dual-channel screen by using the imx8qm-mek-jdi-wuxga-lvds1-panel.dtb,
but when I change it to LVDS0, it doesn't work anymore.
I didn't modify device tree's file name, I just modified the code in device tree.
The device tree for LVDS1 & LVDS0 dual-channel are attached, please check.
I chose the panel-simple.c as the driver, no matter which resouce I set (LVDS0 or LVDS1) in dtsi file, the panel-simple.c always fetch the string "lvds1-panel" in the boot message, even I've already modified from lvds1-panel to lvds0-panel in the dtsi file, like the following boot message:
[ 2.079883] panel-simple lvds1_panel: supply power not found, using dummy regulator
Another wired boot message was as followed:
[ 2.054178] imx-drm display-subsystem: parent device of /bus@56240000/ldb@562410e0/lvds-channel@0 is not available
I've no idea why it shown lvds-channel@0 is not available.
The board I use is i.MX8QM EVK.
Please help and support.
Fox-BCJim
795件の閲覧回数
igorpadykov
2 返答(返信)
796件の閲覧回数
igorpadykov
Hi Jim
may be useful to look at i.MX8QXP lvds0 example
https://source.codeaurora.org/external/imx/linux-imx/tree/arch/arm64/boot/dts/freescale/imx8x-mek-jd...
788件の閲覧回数
Fox-BCJim
Hi igorpadykov,
Thanks for your feedback, I've tried that but got the same result...
Fox-BCJim
