Imx6 SoC has variants, Single , Dual, Dual lite.
Could some one tell respective .dts files for these variants.
I can see the relevant one only is
imx6q-sabresd.dts
I know above things. I guess I have not put forward my question straight.
imx6dl.dtsi
imx6dl-sabreauto.dts
imx6dl-sabreauto-ecspi.dts
imx6dl-sabreauto-flexcan1.dts
imx6dl-sabreauto-gpmi-weim.dts
imx6dl-sabresd.dts
imx6dl-sabresd-hdcp.dts
imx6dl-sabresd-ldo.dts
imx6dl-wandboard.dts
imx6q-arm2.dts
imx6q-arm2-hsic.dts
imx6qdl.dtsi
imx6qdl-sabreauto.dtsi
imx6qdl-sabresd.dtsi
imx6q.dtsi
imx6q-sabreauto.dts
imx6q-sabreauto-ecspi.dts
imx6q-sabreauto-flexcan1.dts
imx6q-sabreauto-gpmi-weim.dts
imx6q-sabrelite.dts
imx6q-sabresd.dts
imx6q-sabresd-hdcp.dts
imx6q-sabresd-ldo.dts
imx6q-sbc6x.dts
imx6sl.dtsi
imx6sl-evk-csi.dts
imx6sl-evk.dts
imx6sl-evk-ldo.dts
Lets take SabreSD Board.. Which DTS file we should refer for Single, Dual, Dual Lite and Quad models.
q for Q and Dual
dl for Dual Lite and Solo
sl for Solo Lite
Would be much helpful if you can tell single dts file for ex:-
imx6dl-sabresd.dts :- I belive its for SabreSD dual Lite models
Like Solo lite I am seeing this
imx6sl-evk-csi.dts
imx6sl-evk.dts
imx6sl-evk-ldo.dts
which one is correct?
dual lite and solo share the same but with different core number.
imx6sl-evk-csi.dts with csi and ldo bypass version
imx6sl-evk.dts without csi and ldo bypass version
imx6sl-evk-ldo.dts without csi and ldo enable version
Hi Biyong,
I think CSI stands for 'Camera Serial Interface'. But what does LDO stand for?
Dhaval
CMOS Sensor Interface (CSI)
It is for using the internal PMU LDO or not.
Please check the datasheet.
IMX6SLCEC.pdf
cd kernel_imx/arch/arm/boot/dts
ls |grep dts|grep mx6
