In the description of the i.MX6DQ RM of sect 8.5.2.3 Firmware Configuration Block,
If does not Boot from RAW NAND flash, may not be held in the NAND flash in this format?
Solved! Go to Solution.
Hi Tahashi
right, if boot from NAND flash is not used
this format (FCB) can be omited.
Hi Tahashi
