Does not boot of RAW NAND
1,256 次查看
takashitakahash
In the description of the i.MX6DQ RM of sect  8.5.2.3 Firmware Configuration Block,
If does not Boot from RAW NAND flash, may not be held in the NAND flash in this format?
标签 (2)
1,111 次查看
Hi Tahashi
right, if boot from NAND flash is not used
this format (FCB) can be omited.
1,112 次查看
Hi Tahashi
