Dear All,
According to i.MX6SL's datasheet, 1.5V is supplied to the NVCC_1P2V port when using Revision B IC, but when using Revision C IC, is it correct to change it to 1.2V or supply 1.2V to both Revision B and Revision C? Can you give me clear answer?
In addition, if the supply voltage spec of NVCC_1P2V is 1.2V regardless of DDR in Revision B and C, please let us know what kind of problems could arise if 1.47V is supplied to NVCC_1P2V Port in i.MX6SL Revision B IC.
Thanks in advance.
