DRAM_SDCLK_0 and DRAM_SDCLK_1
1,270件の閲覧回数
dqz
about imx6 DDR3 design,there is no need to connect DRAM_SDCLK_0 and DRAM_SDCLK_1 with CK of DDR3?
iMX6 SabreSD board do not use  DRAM_SDCLK_0 and DRAM_SDCLK_1 ,but some other board use them ,i want to know what is the effect of DRAM_SDCLK_0 and DRAM_SDCLK_1? thanks
982件の閲覧回数
jan_spurek
Hello Dq,
these pads serve as clock access points. By default the 0R resistors are not mounted and their pads are bridged by
scratching planes.
Jan
3 返答(返信)
982件の閲覧回数
jan_spurek
Helo Dq,
clock always has to be provided to the DDR3 device. i.MX6 SabreSD uses DRAM_SDCLK_0 and DRAM_SDCLK_1. Could you please share the schematic from which you determined that those clocks are not used?
Jan
982件の閲覧回数
dqz
983件の閲覧回数
jan_spurek
Hello Dq,
scratching planes.
Jan
