Whenever I play with android GUI, no video, just navigate through settings, the android crash/hang after few seconds.
I'm using android kitkat with kernel based on the fsl kernel 3.10.17 with custom board similar to the sabresd one.
Here's some info/error from logcat about SurfaceFlinger:
I/SurfaceFlinger( 144): renderer : Vivante GC2000
I/SurfaceFlinger( 144): version : OpenGL ES 2.0
I/SurfaceFlinger( 144): extensions: GL_EXT_debug_marker GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_EGL_image GL_OES_depth24 GL_OES_fbo_render_mipmap GL_OES_fragment_precision_high GL_OES_rgb8_rgba8 GL_OES_stencil1 GL_OES_stencil4 GL_OES_texture_npot GL_OES_vertex_half_float GL_OES_depth_texture GL_OES_packed_depth_stencil GL_OES_standard_derivatives GL_OES_get_program_binary GL_EXT_texture_format_BGRA8888 GL_IMG_read_format GL_EXT_blend_minmax GL_EXT_read_format_bgra GL_EXT_multi_draw_arrays GL_APPLE_texture_format_BGRA8888 GL_APPLE_texture_max_level GL_ARM_rgba8 GL_EXT_frag_depth GL_VIV_shader_binary GL_VIV_direct_texture GL_OES_mapbuffer GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_EXT_multisampled_render_to_texture GL_VIV_clamp_to_border GL_OES_vertex_type_10_10_10_2 GL_EXT_texture_type_2_10_10_10_REV GL_EXT_texture_filter_anisotropic GL_OES_element_index_uint
I/SurfaceFlinger( 144): GL_MAX_TEXTURE_SIZE = 8192
I/SurfaceFlinger( 144): GL_MAX_VIEWPORT_DIMS = 8192
E/cutils-trace( 144): Error opening trace file: Permission denied (13)
E/SurfaceFlinger( 144): HWComposer: framebufferTarget is null
I/iptables( 142): iptables terminated by exit(3)
E/Netd ( 142): exec() res=0, status=768 for /system/bin/iptables -t filter -A INPUT -j fw_INPUT
D/SurfaceFlinger( 144): Screen acquired, type=0 flinger=0x78318450
I/ip6tables( 142): ip6tables terminated by exit(3)
E/Netd ( 142): exec() res=0, status=768 for /system/bin/ip6tables -t filter -A INPUT -j fw_INPUT
W/SurfaceFlinger( 144): Ignoring duplicate VSYNC event from HWC (t=0)
And there is more than 14000 occurance of the last message!
What's is the cause of those 14000 message of "Ignoring duplicate VSYNC event from HWC (t=0)"?
Is there some way to check if the android graphic stack can function properly?
Sometimes there some messages like this
[ 325.901798] binder: 143:805 transaction failed 29189, size 164-
Hi oussama
had you customized board Device Configuration Data (DCD)
(mx6q.cfg) with new DDR settings running DDR test ?
i.MX6 DDR Stress Test Tool V1.0.3
Hi oussama
as far as I know kk4.4.3 (kernel 3.10.17) is not released yet and it is beta,
what is about IMX6_KK442_100_ANDROID_SOURCE_BSP
or just linux - is it also crashing ?
Hi oussama
suggest to use IMX6_KK442_100_ANDROID_SOURCE_BSP
soon kk4.4.3 will be released so one can try it later.
